Three hours deep in my troubleshoot and now I believe it's time to reach out. Got Teleport a couple of months back and applied it to my streams without any issues. Two weeks in-between my last stream and today, I ran into a new and unexplainable problem. So to speed up the story and preface, I did have my internet serviced about 3 days ago. It was just issues with my Upload speeds being wacky. It was solved. However, I did not check back in into obs until today. Now moving into opening obs and running teleport, that's where things took a swerve. I noticed initially that my Teleport source was showing a black screen.
This is how I broke it down:
-Confirmed gaming PC was only instance with teleport "Enabled".
-"0" was set on "Port" still.
-Identifier had not changed since last stream.
-Both pc's were on the same 5G network (one with ethernet, and one with wifi as it had worked multiple streams prior)
-Checked "Advanced Firewall Options" and made a new rule to allow for private networks to allow OBS(and plugins).This was not necessary before. (C:\Program Files\obs-studio\bin\64bit\obs64.exe)
-Completely disengaged "Private Firewall". This was not necessary before.
-Uninstalled OBS and teleport entirely off both platforms. Then reinstalled. (Obviously, wasn't necessary before lol)
-Reset Wi-Fi Router. Still nothing.
The conclusion I came to is that my network may not be allowing teleport to go through between both PCs (obviously, lmao). Why this is, and out of nowhere, baffles me. I just can't pin down these two things: Is it my Streaming PC not being able to receive the teleport signal or my gaming PC not properly sending it?
Streaming PC
https://obsproject.com/logs/OEORxK2dYS48ueWr
Gaming PC
https://obsproject.com/logs/f6I31RHLMDXokEOt
Any help would be appreciated. This destroyed my brain in an attempt to understand how or why this even happened.
