Teleport
Teleport 0.8.0
I had a question regarding obs teleport and having the scenes setup on the gaming pc to then be sent to the secondary pc, I have it setup this way and when I change scenes it seems to play whatever audio on that scene but the video signal does not change or update though the teleport data for it is there, but the thing is going back to that scene that it originally way on that video signal will play like normal. I was wondering if that was normal, if thats intentional, if I should have it setup a different way or its a bug.
I figured out what the issue is, and was wondering if there was a way to auto hide a teleport source once its no longer active or just to disable the source if the source is not playing.
How do i change the network card teleport uses. I have a direct line to the stream pc and i would like to use this network as this is the 25gig network
The discovery should happen over all interfaces. So one would select the one with the IP belonging to the desired interface.
Guys Help me setup obs teleport i did everything firewall app ports and everythings still my gaming pc is not showing in refresh list
Which firewall app and under which OS are you running? If you are running under Windows, I'm not sure whether this has ever been addressed, but my experience with Comodo's firewall app has hampered Teleport's discovery while not fouling NDI's discovery methods. That is because Comodo mistakenly disallows multicast traffic used for discovery (explainer incoming; stay tuned). Windows' own firewalling software works the best with both. Depending on the package you use other than these two (with which I have experience), as the old saying goes, YMMV.
Backgrounder which is a liiiiiitle bit long, but stick with me. You can thank me later. ;3
This is because Teleport uses multicast to discover local peers for pulling Teleport feeds. Multicast uses different, specially-allocated IPv4 blocks of "subnets" in the 224.x.y.z subnet and above which will allow all the computers on your network that your computer on the same network to "be found" by your and possibly others' computers and allow you to find those computers and the use those computers' associated resources. The local network location protocols Internet standard mDNS (multicast DNS) and Apple's Bonjour also use multicast which do not require any configuration to work other than "Hey, I can use other computers near me on my network!". I had not tried Comodo with other multicast-based discoveries like the aforementioned mDNS or Bonjour, which are both well-established standards. Bearing that in mind, should Comodo work with mDNS or Bonjour, if Teleport uses its own implementation of multicast discovery instead, it would explain a great deal.
Hope this helps.
--Katt. =^.^=
P.S. Given that Teleport runs under Windows, macOS and Linux, I can only help under Windows since I use it the most, but I don't use OBS Studio just yet under Linux and I will keep my damn fool mouth shut about Macs. >;3
Is there anyway to stop audio from playing if the audio thats playing is in a different scene on the gaming pc?
no matter if I mute the audio track or switch to a scene without the audio track it will still play, as long as it has its own scene.
Haven't used this plugin for a bit and would like to clean up my system. Teleport shows in OBS but is NOT listed in the OBS plugins folder or in Windows Add/Remove Apps. How does one delete this?
Hi, I have a weird thing happening and I haven't seen it mentioned so here it is
When i copy paste de "obs-teleport.dll" in the "obs-plugins" - "64" folder my obs crashes at launch but only on one of my pc. The other one works perfectly fine. Obs launches properly when I delete the "obs-teleport.dll" but then I only see this pc port in the teleport tab whereas on the other pc, even if I delete the "obs-teleport.dll" I still see both ports.
I don't understand anything please help!
Feature request:
Can we add an option to put the equivalent of a render delay filter on the toolbar section of teleport so that you can use the sending computer's memory and processing for the delaying the outputting rendering/audio instead of the receiving computer's?
Right now the only way I can find to do that appears to be to either to add render delay to each individual element (which takes a lot of resources), or to create a nested scene with the first scene inside of it that has the render delay filter on it and then teleport that from toolbar, which means you have to be in studio mode to change the elements - which is a real hassle.
I recognize my needs are a little unique (I'd imagine most people have to opposite issue with the delay caused by sending needing the receiver to sync in the opposite direction).
Or maybe somebody knows of a plugin or option that I can use conjunction that already does it. I haven't found one outside of nesting scenes.
Feature request:
Perhaps try https://obsproject.com/forum/resources/beam.1705/
It kind of picked up from Teleport and added a lot of things to it for special use cases. If I remember correctly it also had some delay options to compensate for potential lags and resulting audio issues.
hello, how can i uninstall the plugin? thanks a lot for any help
If you are using Windows, you'll usually go into the area where you have your OBS Studio installed, with the default installation rooted at C:\Program Files\obs-studio, look in obs-plugins\64bit for obs-teleport.dll, then delete it. You will likely need to tell Explorer you'll need elevated privileges to remove that file.
Someone else will need to help with Linux and macOS.
--Katt. =^.^=
Thankyou for the continued work on Teleport.
I do wonder if it would be possible to do a standalone client - particularly for linux. I would love to use teleport on minipc's at church to show the service realtime in other parts of the building.
Regards!
Regards!
No. And I think it is more complex than it initially looks. I would recommend to build something around libobs with websockets than to re-implement the bits and pieces OBS has already taken care of.
