obs-shaderfilter
obs-shaderfilter 2.6.1
Hi @Exeldro. Apologies if this has already been reported but after updating to the OBS 33 beta, the Shader Filter plugins seems to have broke.
I'm not Exeldro or a programmer, but from my experiences you might want to try to reinstall his Shaderfilter? I do this with .lua's all the time after each upgrade. I think I did it once or twice with some of Exeldro's plugins, but I think once or twice he needed to fix it and he did. First I would manually delete it from the plugins folder then reinstall it with the installer. Best!.....I'm on a Mac and I will wait before updating based on your experiences.
Appreciated, apparently it's due to how obs handles graphics processing in version 33. We'll have to wait until effected plugins are updated for them to function propery again.
Photoshop-like Layer Styles
Stroke / Drop Shadow / Inner Shadow / Outer Glow / Inner Glow / Bevel & Emboss / Color Overlay
  • layer_styles.zip
    layer_styles.zip
Hi Exeldro,
I took a risk. I installed 33 beta. Shaderilter comes up as an error in plugin manager and doesn't show in the menu. It also doesn't show in the plugins folder. I did try to download the above fix, but don't understand how to go about installing it. I am on a MAC OS Ventura. Thanks so much!....I just reinstalled 2.6. in 32. beta and it's not showing also your draw isn't showing up either. Unfortunately some other cool ones aren't either.
Hey there, any chance we have an update for OBS33? Not immediately the new full compatibility but other plugins are still working as legacy and this one failed to load with OBS33.
Thanks.
@Samisama I made a fix for it. I am waiting for a code signing certificate. If that does not come before OBS 33 becomes stable, I will make an unsigned release. Test builds can be found on GitHub actions.
Thanks, the fix works for me on version 33 of OBS.
i don't know what i am doing wrong, i'm stuck. i installed 2.6.1 after updating to OBS 33, but the existing filters continue to say no properties available and User Defined Shader is not showing up in the filter dropdown list. tried uninstalling and reinstalling, and installing via direct file copy from the non-installer download. windows 11.
For pre-update testing I tried to install this on a portable instance of OBS 33.
The folder structure in the zip (obs-shaderfilter-2.6.1-windows.zip) still reflects the old OBS plugin folder hierarchy and did not load for me when extracted to its home in the portable instance.
I then manually arranged them as such using the 64 bit dll/pdb.
OBS33PortableTestInstance\plugins\obs-shaderfilter\
├── obs-shaderfilter.dll
├── obs-shaderfilter.pdb
└── data\
The plugin then shows up in OBS this way and the filter can be added, but when trying to load from the example effects, the filters don't actually impact the source regardless of which example is used or its settings.
This folder structure mismatch is also true of other excellent Exeldro plugins I use (3d effect, move transition) but those function as intended when I manually arrange the folder hierarchy for the new plugin paths.
Am I doing something wrong?
