LyricDisplay - Professional Lyrics Presentation for Live Production
LyricDisplay - Professional Lyrics Presentation for Live Production 7.0.2
peteralaks updated LyricDisplay - Professional Lyrics Overlay for Production/Streaming Software with a new update entry:
LyricDisplay 6.5.0
Bug Fixes:
- Improved production recovery for backend startup, socket failures, chunk-load errors and updater fallback paths.
- Hardened controller authentication, admin validation, localhost access checks and release audit coverage.
- Tightened file and setlist validation to handle invalid files, unsafe paths, oversized setlists and moved/deleted files more reliably.
- Fixed fullscreen projection bug on same laptop screen on Linux/MacOS by adding Esc key closure for opened outputs...
LyricDisplay 6.5.3
Bug Fixes:
- Fixed pathless file loading so drag/drop and fallback file-input lyrics are routed through the Electron parser with raw text, preserving user parser grouping preferences.
- Fixed LRC parsing so blank timestamped lines are preserved without visible placeholder characters.
- Fixed OSC /setlist/load so zero-based setlist indexes correctly load setlist items as called by @hdml
- Fixed timer/stage/clock visibility so completed terminal countdowns no longer block idle clock...
LyricDisplay 6.6.0
Added Features:
- LyricDisplay Dock (Beta): Headless mode as requested by @kRHYME7 on Issue #13. The app now ships alongside the main app, a headless mode that basically launches the server alongside other needed background processes to run a custom browser dock from inside OBS Studio without the main app open. This helps for slower machines who cannot afford to run separate app window alongside OBS. Full instructions are in the setup modal accessible through Preferences/Advanced...
LyricDisplay 6.6.1
Added Features:
- LyricDisplay Dock (Beta): Headless mode as requested by @kRHYME7 on Issue #13. The app now ships alongside the main app with a headless mode that launches the server and needed background processes so you can run a custom browser dock inside OBS Studio without keeping the main LyricDisplay window open. This helps slower machines that cannot afford to run a separate app window alongside OBS. Full instructions are in the setup modal accessible through...
LyricDisplay 6.6.2
Bug Fixes:
- Logging and Diagnostics: Fixed logging bug that made pruning of old logs over-aggressive. Also added more helpful diagnostics info to logs.
- Fixed sync outputs bug clearing the lyrics payload from the server memory
- Fixed full screen window projection on Windows that made outputs unfocused on mount (behind taskbar)
- Fixed memory compounding by fixing time display bug where every second tick prompted recalculation for auto-fit.
Added Features:
- Improved...
LyricDisplay 6.7.0
Bug Fixes:
- Improved general app performance specifically around active timer control module window.
- Added handling for MacOS update checks: Since the app is yet to be notarized/code signed, auto-updater failed on MacOS. This is now properly handled and communicated to the user.
- Fixed issue #20 raised by @phdalandan concerning lyrics grouping not being retained. Similar issue raised by user Royce also fixed.
- Preserve scroll position of lyrics list on leaving control panel.
Do you think you can add support for color coding the lyrics?
and also, allow us to manually define the line breaks? I think right now the app automatically does it and I you can't seem to override it.
I'm just realizing there are comments here and OBS didn't notify me Have you recently updated the application? Line breaks have been user-configurable for a while now. And I'll look into the colour coding feature for lyrics. Just to be clear, do you mean colour coding as in visually highlighting live lyrics on outputs?
LyricDisplay 6.7.1
Added Features:
- Timer Scheduler: A new schedule feature to automate the timer control which would automatically move through items in a schedule, timed or untimed with intelligent handling.
- Preview Lines: A new feature, configurable to prevent accidental lyric line clicks where applicable. While turned on, single click and then Enter button or double click sends lines live instead of single click.
Bug Fixes:
- Fixed authentication pending plus brief unusable app state...
peteralaks updated LyricDisplay - Professional Lyrics Presentation for Live Production with a new update entry:
LyricDisplay 6.8.0
Added Features & Improvements:
- New File Navigator: Introduced a smarter, more robust in-app file browser, eliminating the need to open the native file dialog every time lyrics are loaded. Lyric folders only need to be indexed once. The file-saving flow has also been integrated for a smoother overall experience.
- New Preview Route: Added a Multiview page that displays all available outputs and previews in one place. It can also be projected to an external display.
- Improved Song...
Amazing project man and it’s been easy setting up so far (a teensy bit technical especially for the network setup but not too much).
Noticed a small bug though. Background colour setting wasn’t working/applying on the stage display for projected screens.
Overall, I’m really excited to see where this goes. ❤️❤️
Thanks so much for using LyricDisplay
I’ll investigate the issue you reported and get a fix in soon
LyricDisplay 6.8.1
- Added a visual gradient angle control, alongside numeric input and a clearer Reverse action, for easier background gradient adjustment.
- Improved Stage Display lyric transitions for smoother movement between previous, current and next lines while respecting the configured transition speed.
Bug Fixes:
- Fixed select fields retaining focus after an option is selected across the app.
- Fixed Always Show Background not working in fullscreen mode.
LyricDisplay 6.8.4
- Added offline MilkDrop visualizer backgrounds, powered by Butterchurn, to Lyric Video Studio and fullscreen lyric outputs. Lyric videos can react to attached audio, while live outputs animate continuously without requiring an internet connection. Includes 26 curated presets, specific or repeatable random selection, sensitivity and dimming controls, multiple render-quality levels, live presentation and MP4 export support.
- Added a Connected Outputs...
Is there a demo of LyricDisplay being used in OBS?
(I am looking for a solution to in which text can be input (either manually or read from a file) which will then be scrollable, based on a keystroke such as page up, page down, arrow up, arrow down, etc. - NOT automatic scrolling).
When you say used in what do you mean? LyricDisplay is a standalone application and works alongside/integrates with OBS via browser source but control is done entirely on the LyricDisplay app.
There’s a dock mode setup (beta) that lets you control a minimalized interface from a custom browser dock interface inside of OBS for persons who cannot afford having another app running, despite LyricDisplay’s low system overhead.
Everything you mentioned are existing features of the app, though in dock mode, keyboard shortcuts won’t work reliably because the OBS app process would intercept
What I was asking about is a DEMO of the LyricDisplay working with OBS. For example, a video or screen shots illustrating what LyricDisplay can do, when integrated with OBS. Thanks!
