LyricDisplay - Professional Lyrics Presentation for Live Production
LyricDisplay - Professional Lyrics Presentation for Live Production 7.0.2
peteralaks updated LyricDisplay - Professional Lyrics Overlay for Production/Streaming Software with a new update entry:
LyricDisplay 6.2.0
Fixed Bugs:
- Preview outputs modal now bypass output toggle switch to offer lyrics preview even when global switch is off
- Fixed bug where clicking on live search result on online lyrics search modal wasn't loading up lyrics
Features:
- Users can now save their current output settings combo and can be reloaded at anytime from templates modal.
LyricDisplay 6.2.1
Bug Fixes:
- Updated Open Hymnal provider and lyrics loader to include year at top level in readable metadata for song info modal
- Aligned select input fields in preview outputs modal to use global select component
- Fixed check for update service not launching from about app modal
- Fixed reported issue by lukelengl on auto-resetting output settings when control panel is loaded on another machine.
LyricDisplay 6.2.10
Bug Fixes:
- Fixed EW 2009 lyrics import by updating engine to support older DB structures as reported in Issue #10 by @Fodwil
- Enhanced detection logic for EW DB folder and files
Features:
- Added presentation file (.pptx) importer logic to convert pptx files to txt.
- UX Improvements
Download at: https://lyricdisplay.app/download
LyricDisplay 6.3.0 Q1 2026 Update
New Features:
- NDI® Output: Users can now seamlessly broadcast their outputs to NDI® receivers in addition to the default and recommended browser pages.
- External Control (MIDI/OSC): Control all lyric operations on the app externally with instruments and other dedicated streaming devices to further enhance your professional lyric presentation workflow.
- User Preferences Modal: Dedicated menu to control a host of app settings and configurables from appearance to lyrics parsing...
New Features:
LyricDisplay 6.3.10
Added Features:
- Added expanded multi-output workflow with support for more output creation (Output 3–6) and better output management flow.
- Added NDI output registry sync so newly created/removed outputs are automatically reflected in NDI settings and companion resync.
- Added new parser controls:
Quick parser controls
Configurable line-grouping behavior
Smarter refrain/chorus expansion from previously defined sections
Stage-only line parsing support
- Added new user...
LyricDisplay 6.3.11
Bug Fixes:
- Fixed custom output automatic teardown upon deletion from control panel
Features:
- Added configurable line spacing in output and stage settings panel
- Expanded fullscreen mode store to include font size and font colour with their related settings, letter and line spacing, and margins
Do you think you can add support for color coding the lyrics?
and also, allow us to manually define the line breaks? I think right now the app automatically does it and I you can't seem to override it.
LyricDisplay 6.3.12
Added Features:
- Added a new Project Output modal for assigning and managing projections for Output 1/2, custom outputs, and Stage.
- Added a new stageMessages utility for normalizing and managing custom stage messages.
- Added enhanced stage display controls for custom messages and related stage configuration behavior.
Bug Fixes:
- Fixed repeated chorus/refrain marker parsing bug.
- Fixed stage settings and stage output sync/UX issues tied to custom display controls.
LyricDisplay 6.3.15
New Features:
- Added dedicated timer module with new /time routing and page for dedicated timer display with custom, robust control panel for all timer related functions and customization
- Added Security key management in advanced preferences
- Minor UI enhancements and tweaks to improve your LyricDisplay experience
Bug Fixes:
- Fixed label issues in dark mode for some modals
- Fixed projected outputs cleanup and active list refresh
- Numerous minor bug fixes
LyricDisplay 6.3.16
Bug Fixes:
- Smart deduplication of global modals especially Project Output modal. Max number of global modals openable at same time capped at 3.
- Removed unresponsive lyrics providers (Vagalume and Hymnary.org) due to bad gateway, no proper support, etc.
- Fixed window layout for Timer control module plus other fixes to improve overall usability.
Added Features:
- New User Media modal that allows users to select and re-use videos/images from their computers for use in...
LyricDisplay 6.4.0
Bug Fixes:
- Fixed timer control module settings and values to persist on app restarts
- Fixed minor bugs on projection output modal
Added Features:
- OBS Source Creator Window: Uses OBS WebSocket protocol to remotely connect to OBS if running on same computer to create a LyricDisplay output browser source from within the app interface. For network setups, users would be required to enter provided network URL on the OBS system's browser and create the browser source from...
LyricDisplay 6.4.1
Bug Fixes:
- Refactored routing and lazy loading in main App entry point to address high memory usage when timer control module is opened.
- Fixed main app window crashing when timer control window is open; added production logging feature to catch future window crashes.
- Fixed project output modal's visibly overflowing footer.
- Fixed preview outputs modal display points not showing lyrics until global toggle.
- Fixed structure tags parsing bug for some songs by expanding tag list...
LyricDisplay 6.4.3
Bug Fixes:
- Fixed OOM Crash due to memory ballooning from main app process when timer is running with control module open. A soild and final enhancement to previous fixes.
- Legacy user data folder migration and cleanup tightened to remove old, unused folders.
- Fixed user preferences modal and quick parser settings sync bug.
Added Features:
- New, focused output settings templates for diverse use cases.
