atkAudio Plugin
atkAudio Plugin 0.32.2
yup this totally resolved the sync issue, however some users reported when I'm switching to replays now there's a pop when the audio starts, dunno if it's a dc offset. Thanks for your continued development of this great plugin.
Great sounds like pops are resolved, i did have a crash on scene change but who knows if it was related to ATK. Thank you again!
I don't know if this is related to ATK but transitioning between scenes now hard cuts the audio when in older versions I remember it cross fading or fading out on scene switch. Any ideas on what would've changed in OBS or is this a potential ATK thing?
In DeviceIos there are very short (one buffer) technical fades. But they are not the kind of humanly audible fade ins/outs.
I would like to see if this will fix my issue with getting multiple inputs from my audio interface into different sources in OBS. I installed it using the .pkg installer (macOS), but it's not showing up in my list of available filters. When I look at the log file, I see the following:
12:02:09.361: os_dlopen(/Users/x/Library/Application Support/obs-studio/plugins/atkaudio-pluginforobs.plugin/Contents/MacOS/atkaudio-pluginforobs->/Users/x/Library/Application Support/obs-studio/plugins/atkaudio-pluginforobs.plugin/Contents/MacOS/atkaudio-pluginforobs): dlopen(/Users/x/Library/Application Support/obs-studio/plugins/atkaudio-pluginforobs.plugin/Contents/MacOS/atkaudio-pluginforobs, 0x0105): Symbol not found: __ZN11QMetaObject16invokeMethodImplEP7QObjectPN9QtPrivate15QSlotObjectBaseEN2Qt14ConnectionTypeExPKPKvPKPKcPKPKNS2_18QMetaTypeInterfaceE
12:02:09.361: Referenced from: <38F388EE-8905-334C-8668-FAFE84B54BF7> /Users/x/Library/Application Support/obs-studio/plugins/atkaudio-pluginforobs.plugin/Contents/MacOS/atkaudio-pluginforobs
12:02:09.361: Expected in: <AFB27054-0020-30B0-8AED-13694241A31C> /Applications/OBS.app/Contents/Frameworks/QtCore.framework/Versions/A/QtCore
12:02:09.361:
12:02:09.361: Module '/Users/x/Library/Application Support/obs-studio/plugins/atkaudio-pluginforobs.plugin/Contents/MacOS/atkaudio-pluginforobs' not loaded
Any recommendations for getting it to find it correctly? Appreciate the help!
12:02:09.361:
what OBS version?
It's up and running now, I just need to figure out how to get it to properly isolate separate inputs from my audio interface. OBS just treats my interface as one giant input, and anything coming in to any channel shows up on the one fader. Can the plugin do this?
disregard- I got it up and running. This is a godsend, I will be contributing. Sorry to muck up the thread with extra replies.
Input and Output selections in the audio settings in pluginhost 2 don't save after closing
