Zoom Streaming
obsbuddy
Is it possible using OBS to connect 2 zoom streams , I have the following toplogy :
As you can see Zoom 1 is fed into OBS1 -> and stream is transmitted over NDI to OBS2 which then throws it to Zoom 2 , in this case , Zoom 1 participants are visible to Zoom2 folks , my requirement is that Zoom1 participants should also be able to see Zoom2 participants , can someone suggest if that can be achieved by making any change in this topology or any other way it can be achieved?
Thanks
