I was successful in using Wyze Cam v2 with the RTSP firmware with OBS through this configuration with a 'Media Source'.
After you flash your Wyze Cam with the update firmware here, use the following configuration:
- Uncheck Local File
- Input: rtsp://username:[email protected]:554/live
- Input format: ffplay
substitute above with the username and password you configured through the Wyze App, Advanced Settings/RTSP.
Replace 192.168.x.x with your IP address.
