Using curlftpfs to publish HLS stream on a remote host
Filip S
Member
I did find something about using HLS steaming on OBS using the record option and ffmpeg.
https://obsproject.com/forum/resources/how-to-do-hls-streaming-in-obs-open-broadcast-studio.945/
But I only ftp/ftps acces on web hotel provider.
It looks like the FFMPEG can do ftp also but did not like to fill the server with alots of *.ts files so I did try to make my nginx on the small raspberry PI4 using curlftpfs to mount access to the hls directory on the remote server like this:
curlftpfs -o allow_other ftp://useraccount:[email protected].dk /mnt/remotehost
Then the nginx is used to make the HLS to a remote FTP/Webserver but the nginx did not accept to use the mounted (hls_path /mnt/remotehost/hls;) so luck with that.
Nginx did give me problems with the permissions but it would have been a very nice solution – maybe someone can explain why its not working for me and why nginx complains ?
So using a local mounted device and it would be possible use rsync to keep the hls directory with files simular was testeted but rsync was making som *.tmp files and the remote ftp was not really working the way I needed – I found a way using this:
rsync -v -r -c --inplace --delete /var/www/html/livestream/ /mnt/remotehost/www/xxx.hosting.dk/hls
This should be working but I suspect the way nginx is making the *.ts files are not the same way the ffmpeg does via the OBS record way – playout works fine local on nginx after rsync.
Using OBS ffmpeg recording writing to the /mnt/remotehost/hls is working just fine on my OBS computer with the mounted remote host on my Linux Obs computer.
curlftpfs is available on most unix/linux distributions also https://helpmanual.io/help/curlftpfs/
Maybe the nginx is making the *.ts files encrypted with some timeout it can play but another webserver can not just publish the files – I am not really sure about this but maybe someone on this community know why and possible change nginx to make simular files like ffmpeg do in OBS.
I am no really sure what webserver my webhotel is running possible apache.
Anyway following the OBS guide
and using curlftpfs did work on my OBS computer and on the remote webserver.
My goal was to use nginx to make the HLS stuff so no a complet succes with that but it should be possible using srt or rtmp to make the HLS.
Any suggestions ?
