[TWITCH] Widget Top Combo Emote (Twitch/BetterTTV/FFZ/SevenTV)
pabloalber84
pabloalber84 submitted a new resource:
[TWITCH] Combo of Top Emote for Twitch (Twitch/BetterTTV/FFZ) - Display combo of top emote of chat.
Hi everyone,
About:
This Widget works to bring in layout of streaming one the top combo emote of the chat, only you need configure to get URL and put in Widget HTML Show at any streaming software.
Actually works with suscribers emotes, BetterTTV Global Emotes, BetterTTV and FFZ channel emotes (All rights to emotes/extensions to their respective creators/developers)
I writted 90% of the main code.
Is 80% javascript project, is free for use ONLY in the webpage, from the url than you...
V2.1 ADDED!
  • Added "style to display" config, you can now use 3 different styles (Default: x[Counter] [Image Emote] combo!)!
  • Added "font" config, you can now use 6 different font's to text (Default: Arial)!
  • Added visual preview in generator (only to show the font and style to display)
  • Added "text align" config, you can now set the text align to Top, Middle or Button (Default: Middle)!
  • Fixed bug that made some emotes (Like BTTV emote "OMEGALUL") was taken as LUL!
  • Fixed bug with default emotes with characters specials (":D" ":-D") dont take counter on started emote!
pabloalber84 updated [TWITCH] Widget Combo of Top Emote for Twitch (Twitch/BetterTTV/FFZ) with a new update entry:
V2.1 ADDED!
  • Fixed bug with...
IMPORTANT! PEOPLE USING WITH SUSCRIBERS EMOTES!
If you want to use combo emotes widget with your's suscribers emotes, submit your channel to TwitchEmotes, you only need to submit your CHANNEL NAME, and the api can share your suscribers emotes to the widget and can be used.
This submit can take effect next 24 hours approx (probably less).
New WEB and Functions!
New page, you can create 5 max. different combo widgets.
Images: https://imgur.com/a/yjO4Xc7
What news:
> Secure Login with Twitch (Check Terms and Conditions and Privacy Policy).
> New interface and functions
> Selectable animations in-during-out combo.
> URL shorter
> Share your widget to another people
> Now, you can reload your config in OBS during livestream with the command...
Cache issues.
If your widget combo emote seems to be unresponsive or not working, try joining them on WEB to store cache from them.
Try in panel, click on "URL".
And click on "Redirect".
This will create cache of your URL and it will fix it, you will not experience future related problems.
If not working, contact me on [email protected]
V1.2.6 Update (NEW PAGE)
> Fixed some loading times.
> Fixed problems when new combo coming.
> Fixed test page combo counter.
> Now you can use "No animation" on animations configs.
> Added "Gray Effect Out" (Default ON), to add gray effect when it comes out, its now optional.
> (Optional) Added "Anim During [COUNTER (+)] " animation! Basically, when the counter goes up, they goes up with a animation.
> Added new vertical style " (Vertical) [Image Emote] x[Counter]!"
(Recommended...
V1.2.7 Update (NEW PAGE)
> Fixed problem related with animation "Anim During ", now worked properly.
> Fixed problem related with chat commands (Widget don't detect !ce commands).
> Added "Sync Anim During Counter - IMG"
[ATTACH type="full"]71649[/ATTACH]
To take effect update's, use in chat command "!ce reload" while you are in OBS (Same for update config).
[CENTER][B][SIZE=6]♥ THANKS FOR USING MY WIDGET ♥
WE REACH 1000 STREAMERS USING IT[/SIZE][/B][/CENTER]
pabloalber84 updated [TWITCH] Widget Top Combo Emote (Twitch/BetterTTV/FFZ/SevenTV) with a new update entry:
V1.3.3 Update (NEW PAGE)
> Fixed FFZ from BTTV: Emotes don't load
> Fixed bug with twitch emotes: Random combo emote appear with twitch emote without starting in correctly counter.
> Added option "Dynamic Emotes": Now you can allow to get external emotes and take count of it in combo emotes (When new emote get's detected, gets cached).
(Default: Enabled).
> Added option "Counter Algorithm" with two options:
  1. Traditional Mode: Counts all emotes used in real time, if one emote reach emotes needed to...
V1.3.7 Update (NEW PAGE)
> Optimized widget load.
> Fixed bug that bring double combo on the window.
> Added option "Anim Counter Decrease": Now, when the emote combo is ending, the counter will decrease to 0 with an animation (before use animation out).
> Modified option "Text Stroke", added white and black stroke.
> Added new display style that shows emote name (BETA):
> Added two more styles of fonts.
> Added option "Streamer Preset", this give you a preset of...
