Streamlabs Plugin for OBS
Streamlabs Plugin for OBS 09/28/2026
Streamlabs
skaiser submitted a new resource:
Streamlabs Plugin for OBS - Access alerts, overlays, stream labels, and other Streamlabs tools from inside OBS studio
Add alerts and overlays, engage with your audience in chat, and add your favourite widgets -- all without leaving OBS studio.
  • Widgets, Overlays: Customize the look and feel of your stream with access to thousands of professionally designed animated overlays, alerts, widget themes, and scene transitions. Install overlays in one click, and add essential widgets like Alert Box, Chat Box, and Event Lists.
  • Cloudbot: Connect to Streamlabs Cloudbot to enable giveaways...
Greeting How to install it? And does it fix AUDIO (Control Audio via OBS) stuttering for alerts/dotantion alerts web?
Is this tied to the profile? Because I stream to different channels, and would like to have an easy way toa lso switch between Streamlabs Accounts
Is anyone else having issues connecting to the Streamlabs chat feature of this? I can see the activity feed, but the chatbox just throws up an error that I am not authorised to use it then to retry then it gives me the message below
Hey everyone,
I notice the plugin breaks my overlays.
So, I plan on using it solely for Streamlabels and alerts.
All my graphics for the overlays are stored on my NAS. After installing the Plugin, the NAS drive is no longer visible in the OBS dialogues. It worked flawlessly before.
The dodgiest plugin I've ever used casuses many crashes, forces the user to jump through hoops , widgets fail.
