Streaming to a managed YouTube channel.
nschwa115
I am trying to set my obs client up to stream to a channel that my YouTube account is a manager for, but I'm not seeing any way to switch what channel the broadcast manager goes to.
Is this a feature that's still in the works, am I just missing a step, or is the only way to get this to work is to sign into channel owner account?
Thanks
This is something that is really wanted for us. This way we can give every different machine that we use a unique account. Using a stream key is really undesirable for us.
So, no update on this? I have the same issue. I would prefer not having to look for the stream key, as I have to manage a few different livestreams one after the other, and having them listed is way easier.
not an update so much as another work-around: Advanced Scene Switcher can set the stream key, so you can create macros to start each of your streams and set the key accordingly. Depending on your needs, you could have them trigger with time, or create buttons, or whatever else you want that AdvSS supports.
