Streaming on debian (KDE) without a screen
saschaheinl
Hi everyone,
I’m looking to livestream sports events and have a question regarding a basic setup.
There will be two courts that need to be streamed. Each court will have the same configuration: 1 Debian 12 computer and 1 video camera connected to the computer using an HDMI capture card.
At the last event, I had only one monitor for three computers and needed it for the one used for match control. So, I set up the stream, started broadcasting, and then unplugged the monitor to set up the second stream. However, once I set up the second stream, I noticed that the first one stopped broadcasting. When I reconnected the monitor, I realized that the window manager had crashed (see attached image).
Luckily, I was able to borrow two Windows laptops from a friend, which I typically use for streaming, and that saved the day. Does anyone have suggestions for a more stable setup?
Thanks in advance!
Greetings from Germany
Basic monitors are pretty cheap now. :-)
If you don't have the space for that, you might look at an EDID Emulator. This one came up in about 30 seconds of searching:
It makes the computer think there's a monitor there...
