Retro Effects
Retro Effects 1.1.1
Apologies for that being confusing. At the time I pushed this update, the forum only allowed us to attach 5 files to be downloaded, so I needed to bundle some of them together rather than having separate downloads. The mods have now bumped it up to 7 files, so for future releases I'll be able to separate that out.
No apologies accepted, lol! Thank you for noticing the incongruent packaging, explaining the situation and already planning to separate it out. Sidenote, Still 7 seems quite low, la sigh, especially with Linux, ms, mac, and OBS now needing separate versions for switchover from v32 -> v33. Not sure the full extent, but couldn't installer/script destinations be based on installed OBS version? $( obs --version)
All the best - Have a great week and Halloween!
FiniteSingularity updated Retro Effects with a new update entry:
Installer Bugfix 1.1.1
This is a bugfix for the Windows Installer for Retro Effects. If you were having issues installing Retro Effects 1.1.0 with the windows installer, please give this version a try.
NOTE: I have included separate zips/installers/debs compatible with OBS 33+ and OBS 30-32. Please make sure you download the file labeled with your version of OBS.
Love seeing the updates! One thing I noticed you might consider is putting a version identifier and some text with links to the download at the bottom of the filter settings.. For example:
Oops! I normally have a version identifier at the bottom of the filter panel for my plugins. Somehow that has gone away (or maybe was never there) for Retro Effects. I'll make sure I fix that for 1.1.2. Thank you for pointing that out.
