Reorderable Audio Mixer 1.2.0
thetomcanuck updated Reorderable Audio Mixer with a new update entry:
Minor bump
Kinda just wanted to get a working/workable version out there
So 32.1 introduced some issues. I am aware. Is it perfect? NO. Workable though. My dev environment was never intended to work on multiple OBS versions that had breaking changes. Wasted too much time trying to get both nice, hence the gap between releases, sorry. I have time to focus on this again. So while I dont want to hammer everyone with constant updates because that's annoying, I would expect at least a meaningful update...
Fwog Studios updated Reorderable Audio Mixer with a new update entry:
1.2.0 is live targeting the 33.0.0 update
  • Right-click on a channel now opens the same menu as its three-dots button. Right-click on empty dock space still shows the dock menu.
  • Muted meter colours are exposed as theme properties, which also removes the Qt warnings OBS logged at startup.
  • First macOS build, shipped as a universal (Intel + Apple Silicon) .pkg.
  • Vertical layout finally works as expected when i tested it
Hi, I really love this.
Two suggestions: A one-click solution for monitoring and changing the direction arrows to < and > when in the vertical view.
Regards
It's great to see a reorderable mixer. At the moment the controls are too big for me to fit all my sound sources. I like the look and sizing of the core OBS mixer controls in 33.0.1. I like the core controls narrower meter and a mono channel showing as mono.
If you can shave yours down to match the core mixer control widths and reduce the font size of the labels and make the ellipsis button smaller it would help. Could you colour code the label background for those who need to distinguish the controls easily?
Sometimes I also do need to see inactive controls and hidden controls.
thanks for creating this.
Regards,
David
