rlm1murphy
The problem is that an incorect powerPoint presentation slide is presented.
Let me describe our setup. One PC has NDI and powerPoint running the presentation. The second PC has OBS and Zoom running. There are mutiple scenes, some showing the presentation and some with the presentation.
Initally a powerPoint presentation is presented with several slides and all are presented correctly through OBS with the presentation shown through NDI. Then OBS changed to a scene with just a graphic and without a presentation window, this is shown 10 minutes. A new powerPoint presentation is prepared, started and blanked and OBS is switched to a scene with just a camera input. Now is where the problem occurs. Next OBS is switched to a scene with a camera input and the powerpoint presentation and once the scen is open the last slide from the first presentation is shown. Once the second presentation is advanced to the next slide the correct slide is shown. The rest of the second presentaion continus as normal.
If you have a solution email me at [email protected]
