Only Channel 1 Audio works.
Brukaviador
With the six available audio tracks, I can record my microphone and/or my application to track 1 but can't record anything to tracks 2-5. I've tried all combinations.
If I record them both to track 1 it's fine, but I wanted to split them up to make editing easier.
I've looked at a ton of tutorials that all say the same thing, so I'm sure I'm setting everything up right. I'll include a screenshot of my output settings and the log file below.
I have also completely uninstalled and reinstalled the software, in case it was a glitch.
If anybody can tell me where I've gone astray, I would appreciate it.
This has been driving me nuts all day.
Thanks.
  • 2024-05-27 19-00-24.txt
I mostly played the output file in VLC (which is still in the default saved MKV format), but I've also been importing it into a couple different video editing programs to be sure there isn't an additional audio track I'm not hearing.
Either everything saves to Audio track 1, or the file just has no audio.
So I did get it fixed. Unfortunately, I have no idea what I changed to make it work. I went into Advanced mode, and chose all the same settings I had in Simple mode.
Now it's properly saving everything to channel 1, channel 2 is just my mic, and channel 3 is my game. I can import the file into a video editor, and see all three tracks.
Weird. I guess maybe you only get channel 1 in Simple mode, despite what it looks like.
