Question / Help OBStudio Crash QuickSync H.264
hmm i have driver nvidia and intel hd graphics...installed
So, no crash any more? Please, post your obs log-file after you press the start recording/streaming button.
https://obsproject.com/logs/_KcvYWOxDACvEsKa
or
18:35:33.147: CPU Name: Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
18:35:33.147: CPU Speed: 3600MHz
18:35:33.147: Physical Cores: 4, Logical Cores: 4
18:35:33.147: Physical Memory: 7621MB Total, 5087MB Free
18:35:33.147: Windows Version: 10.0 Build 17763 (revision: 316; 64-bit)
18:35:33.147: Running as administrator: false
18:35:33.147: Aero is Enabled (Aero is always on for windows 8 and above)
18:35:33.147: Windows 10 Gaming Features:
18:35:33.147: Game Bar: Off
18:35:33.147: Game DVR: Off
18:35:33.147: Game DVR Background Recording: Off
18:35:33.147: Game Mode: Off
18:35:33.150: Sec. Software Status:
18:35:33.151: Windows Defender Antivirus: disabled (AV)
18:35:33.152: Windows Firewall: disabled (FW)
18:35:33.152: Windows Defender Antivirus: disabled (ASW)
18:35:33.156: Current Date/Time: 2019-03-02, 18:35:33
18:35:33.156: Browser Hardware Acceleration: true
18:35:33.156: Portable mode: false
18:35:33.770: OBS 23.0.1-9-g0f8c405e (64-bit, windows)
18:35:33.770: ---------------------------------
18:35:33.770: audio settings reset:
18:35:33.770: samples per sec: 44100
18:35:33.770: speakers: 2
18:35:33.777: ---------------------------------
18:35:33.777: Initializing D3D11...
18:35:33.777: Available Video Adapters:
18:35:33.780: Adapter 1: NVIDIA GeForce GTX 1050 Ti
18:35:33.780: Dedicated VRAM: 4213178368
18:35:33.780: Shared VRAM: 3995856896
18:35:33.780: output 1: pos={0, 0}, size={1920, 1080}, attached=true
18:35:33.780: Adapter 2: Intel(R) UHD Graphics 630
18:35:33.780: Dedicated VRAM: 134217728
18:35:33.780: output 1: pos={1920, 78}, size={1366, 768}, attached=true
18:35:33.783: Loading up D3D11 on adapter NVIDIA GeForce GTX 1050 Ti (0)
18:35:33.842: D3D11 loaded successfully, feature level used: 45056
18:35:34.561: ---------------------------------
18:35:34.561: video settings reset:
18:35:34.561: base resolution: 1920x1080
18:35:34.561: output resolution: 1280x720
18:35:34.561: downscale filter: Lanczos
18:35:34.561: fps: 60/1
18:35:34.561: format: NV12
18:35:34.561: YUV mode: 601/Partial
18:35:34.562: NV12 texture support enabled
18:35:34.567: Audio monitoring device:
18:35:34.567: name: Default
18:35:34.567: id: default
18:35:34.567: ---------------------------------
18:35:34.584: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
18:35:34.592: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
18:35:34.687: [AMF] AMF Test failed due to one or more errors.
18:35:34.687: Failed to initialize module 'enc-amf.dll'
18:35:34.796: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
18:35:34.828: [obs-browser]: Version 2.3.0
18:35:34.872: NVENC supported
18:35:34.943: Couldn't find VLC installation, VLC video source disabled
18:35:34.954: No blackmagic support
18:35:34.971: ---------------------------------
18:35:34.971: Loaded Modules:
18:35:34.971: win-wasapi.dll
18:35:34.971: win-mf.dll
18:35:34.971: win-dshow.dll
18:35:34.971: win-decklink.dll
18:35:34.971: win-capture.dll
18:35:34.971: vlc-video.dll
18:35:34.971: text-freetype2.dll
18:35:34.971: rtmp-services.dll
18:35:34.971: obs-x264.dll
18:35:34.971: obs-vst.dll
18:35:34.971: obs-transitions.dll
18:35:34.971: obs-text.dll
18:35:34.971: obs-qsv11.dll
18:35:34.971: obs-outputs.dll
18:35:34.971: obs-filters.dll
18:35:34.971: obs-ffmpeg.dll
18:35:34.971: obs-browser.dll
18:35:34.971: image-source.dll
18:35:34.971: frontend-tools.dll
18:35:34.971: enc-amf.dll
18:35:34.971: decklink-ouput-ui.dll
18:35:34.971: coreaudio-encoder.dll
18:35:34.971: ==== Startup complete ===============================================
18:35:34.976: All scene data cleared
18:35:34.976: ------------------------------------------------
18:35:35.029: WASAPI: Device 'Headphones (Razer Kraken USB)' initialized
18:35:35.060: WASAPI: Device 'Microphone (Razer Kraken USB)' initialized
18:35:35.110: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds (source: Mic/Aux)
18:35:35.110:
18:35:36.006: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Mic/Aux)
18:35:36.006:
18:35:36.072: Switched to scene 'CS:GO'
18:35:36.072: ------------------------------------------------
18:35:36.072: Loaded scenes:
18:35:36.072: - scene 'CS:GO':
18:35:36.072: - source: 'DESKTOP' (monitor_capture)
18:35:36.072: - source: 'GAME' (game_capture)
18:35:36.072: - source: 'CENZURA' (image_source)
18:35:38.148: [qsv encoder: 'recording_h264'] settings:
18:35:38.148: rate_control: CBR
18:35:38.148: target_bitrate: 10000
18:35:38.148: fps_num: 60
18:35:38.148: fps_den: 1
18:35:38.148: width: 1920
18:35:38.148: height: 1080
18:35:38.148: [qsv encoder: 'recording_h264'] debug info:
18:35:38.154: impl: D3D11
18:35:38.154: surf: D3D11
18:35:38.212: m_nSurfNum: 8
18:35:38.229: [qsv encoder: 'msdk_impl'] Undefined behavior (MFX_ERR_UNDEFINED_BEHAVIOR)
18:35:38.231: [qsv encoder: 'recording_h264'] qsv failed to load
18:35:38.231: major: 1
18:35:38.231: minor: 27
So, it is still crashes but now with popup error window?
From the log I see:
that means:
https://software.intel.com/en-us/node/628431#MFXVideoENCODE_Init1 said:
MFX_ERR_UNDEFINED_BEHAVIOR ... The function is called twice without a close;
so pretty...
The solution here was to use encoder's .dll file from the previous build of obs (v22.x.x) (see https://obsproject.com/mantis/view.php?id=1372 for details)
You may try it too, despite the error in the log a bit different, I think the root of the problem is the same. Just give it a try.
I have two monitors!
If I put the main monitor on VGA on the motherboard I do not have the problem but I want to stay the main one with the GTX 1050 Ti
Please, post the log-file from the attempt where your main monitor connected to the motherboard.
so i connected the monitors but if I pass the 2nd monitor as the primary I do not have the problem with intel quick sync but i want the primary one to remain the first monitor
Did you tried the solution with the old plugin version (.dll from obs v22.x.x) that was mentioned above?
I've found where, but it does.
Normally I have two monitors
Primu monitor is with HDMI in GTX 1050 Ti
The second monitor is VGA in the slot on the motherboard
The problem is that if I leave the primary monitor with the GTX 1050 Ti I do not let me use QuickSync, if I change the primary monitor with the VGA on the motherboard let me use QuickSync but the games will start on it and lower the performance of the game
