Question / Help OBS xcomposite problem
Waishon
I've a problem with adding xcomposite captures of my windows... If I add one i get a red screen in OBS.
This problem didn't exist if I use the nouveau driver, but with the GTX 660 and the Nvidia 304.125 driver.
Errors:
error: xcompcap: glXCreatePixmap failed: BadAlloc (insufficient resources for operation)
If I add Firefox:
error: glCopyImageSubDataNV failed, glGetError returned 0x502
error: device_copy_texture (GL) failed
Here are some usefull informations:
operating system: Elementary OS Freya
I7 3770
GTX 660
16GB Ram
OpenGL:
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GTX 660/PCIe/SSE2
OpenGL core profile version string: 4.2.0 NVIDIA 304.125
OpenGL core profile shading language version string: 4.20 NVIDIA via Cg compiler
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.2.0 NVIDIA 304.125
OpenGL shading language version string: 4.20 NVIDIA via Cg compiler
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
Try the included Nvidia Driver 331 on Elementary OS. i use this with no problems other than known issues such as desynced audio.
Please be aware that Elementary OS Freya is a Beta and is not always reliable to do testing of other software on.
For proper testing do this on Stable releases of distros such as Ubuntu 14.04.
Thanks, I will try it and hope that I dont kill my PC :D
Its not the official beta. Its an other unstable build, but with nouveau it works...
Hi. I experience the same problem. When using xcomposite capture I get red windows in OBS with an error "error: xcompcap: glXCreatePixmap failed: BadAlloc (insufficient resources for operation".
I am using a GTX 970 with 343.36 Nvidia drivers. I got the compositor "compton" running.
I remember when searching for this problem before, there was a thread stating that compton would apply an alpha channel to every window, even if no transparency is used and that would cause problems with OBS.
I can not find that thread again, but does anyone know if this is still the case?
i can say that i use compton and don't have a problem capturing most windows. only an xfce4 terminal, that has a transparent layer so it's a red square. i've posted the bug report on mantis. i would advise everyone with the issue go add your situation here: https://obsproject.com/mantis/view.php?id=133
if an issue has enough people complain about it I would think it gets more attention but that's just a guess.
Hi, this is happening to me as well. I've added some details on Mantis. A 'funny' thing is that the first time I tried OBS there were no problem at all (I tried with Dota 2 and I could stream just fine). The next day I opened OBS to do it again and I found the "red window" problem. I've tried to remember if I changed something on my system but I have no idea...
Able to reproduce most of the errors on my debug build, so a touch more info:
debug: [API][Error]{High}: GL_INVALID_OPERATION error generated. The source or destination texture is not complete.
  • Forced nvidia xorg meta-mode setting "ForceFullCompositionPipeline" on/off had no effect.
  • Other nvidia meta-mode options not able to be tested, they prevent my i3wm from even running :/ (none look like they might do anything anywho)
  • Changing/Disabling transparency of xcfe4-terminal had no effect (might not remove alpha layer if so?).
  • Running with or without compton (compositing manager) had no effect.
From what I could debug (and feel free to guide me with more info on what to look at!) it might be something along these lines:
  • p.tex, p.pixmap, p.glxpixmap and p.glxtex not actually having matching formats (but some how slipping through the sanity checks?)
  • the Xcomposite pixmap becoming invalid and not being updated again. (missed event in XCompcap::processEvents()?)
  • p.tex / p.pixmap alpha layer not set properly in source application (unlikely)
  • p.tex / p.pixmap alpha layer not being passed from xserver (because we don't ask correctly?), causing invalid pixmap state
  • source application is not rendering in xserver (eg minimized window) (had no effect having xfce4-terminal in background or foreground for me with i3wm. Hidden windows also rendered fine, like remmina, or firefox)
Alas this is mostly speculation because I do not quite understand as much as I would like.
For the glXCreatePixmap, I cannot reproduce "BadAlloc" that one (probably due to me using i3-gaps-next over some other WM?) but according to https://www.opengl.org/sdk/docs/man2/xhtml/glXCreatePixmap.xml the "BadAlloc" can come from either inability to alloc the memory, *OR* there is already a "GLXFBConfig" for that pixmap. I am going to admit that my understanding of what that means is basically zero though...
I can reproduce the "glXCreatePixmap failed: BadMatch (invalid parameter attributes)", however I am at a loss on what to even look at for debugging. My simple test of doing "xlock.resetError();" causes indentical 0x502 GL_INVALID_OPERATION Errors. Makes me wonder if they are more related than seems? Root cause something messed up with getting the textures/pixmaps? Again just some wild mass guessing.
Anywho, here is my system information in case that helps:
ffmpeg from PPA, obs-studio is from "0.10.1-50-g92cae0c" (latest when testing)
glxinfo (although I don't think anymore that it is openGL's fault...):
OpenGL renderer string: GeForce GTX 860M/PCIe/SSE2
OpenGL core profile version string: 4.4.0 NVIDIA 352.09
OpenGL core profile shading language version string: 4.40 NVIDIA via Cg compiler
OpenGL version string: 4.5.0 NVIDIA 352.09
OpenGL shading language version string: 4.50 NVIDIA
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.1 NVIDIA 352.09
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
OpenGL ES profile extensions:
xprop -id 14682712 #The xfce4-terminal that failed.
_NET_WM_STATE(ATOM) =
WM_STATE(WM_STATE):
  window state: Normal
  icon window: 0x0
WM_HINTS(WM_HINTS):
  Client accepts input or input focus: True
  Initial state is Normal State.
  bitmap id # to use for icon: 0xe00020
  bitmap id # of mask for icon: 0xe00023
  window id # of group leader: 0xe00001
XdndAware(ATOM) = BITMAP
_MOTIF_DRAG_RECEIVER_INFO(_MOTIF_DRAG_RECEIVER_INFO) = 0x6c, 0x0, 0x5, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x10, 0x0, 0x0, 0x0
_NET_WM_ICON(CARDINAL) =  #SNIPPED FOR SIZE
_NET_STARTUP_ID(UTF8_STRING) = "i3/i3-sensible-terminal/2032-3-admalledd-laptop_TIME175007"
WM_WINDOW_ROLE(STRING) = "xfce4-terminal-1434393212--1075693122"
_NET_WM_SYNC_REQUEST_COUNTER(CARDINAL) = 14682714
_NET_WM_WINDOW_TYPE(ATOM) = _NET_WM_WINDOW_TYPE_NORMAL
_NET_WM_USER_TIME(CARDINAL) = 10850552
_NET_WM_USER_TIME_WINDOW(WINDOW): window id # 0xe00a59
WM_CLIENT_LEADER(WINDOW): window id # 0xe00001
_NET_WM_PID(CARDINAL) = 2828
WM_LOCALE_NAME(STRING) = "en_US.UTF-8"
WM_CLIENT_MACHINE(STRING) = "admalledd-laptop"
WM_NORMAL_HINTS(WM_SIZE_HINTS):
  program specified minimum size: 48 by 51
  program specified resize increment: 8 by 15
  program specified base size: 16 by 21
  window gravity: NorthWest
WM_PROTOCOLS(ATOM): protocols  WM_DELETE_WINDOW, WM_TAKE_FOCUS, _NET_WM_PING, _NET_WM_SYNC_REQUEST
WM_CLASS(STRING) = "xfce4-terminal", "Xfce4-terminal"
WM_ICON_NAME(STRING) = "Terminal_testing"
_NET_WM_ICON_NAME(UTF8_STRING) = "Terminal_testing"
WM_NAME(STRING) = "Terminal_testing"
_NET_WM_NAME(UTF8_STRING) = "Terminal_testing"
xprop -id 35661739 #window ID of obs-studio itself, which works (no red box)
WM_STATE(WM_STATE):
     icon window: 0x0
_NET_WM_NAME(UTF8_STRING) = "OBS 0.10.1-50-g92cae0c-modified (linux)"
_MOTIF_WM_HINTS(_MOTIF_WM_HINTS) = 0x3, 0x3e, 0x7e, 0x0, 0x0
_XEMBED_INFO(_XEMBED_INFO) = 0x0, 0x1
WM_CLIENT_LEADER(WINDOW): window id # 0x2600002
WM_HINTS(WM_HINTS):
_NET_WM_PID(CARDINAL) = 18008
_NET_WM_SYNC_REQUEST_COUNTER(CARDINAL) = 39845897
WM_CLASS(STRING) = "obs", "obs"
     user specified location: 1922, 20
     user specified size: 1916 by 1037
     program specified minimum size: 734 by 254
     window gravity: Static
"inxi -Fz" info for hardware stuff (snipped a bit)
System:  Host: admalledd-laptop Kernel: 3.13.0-24-generic x86_64 (64 bit) Desktop: i3-gaps-next Distro: Linux Mint 17 Qiana
Machine:  Mobo: ASUSTeK model: G551JM version: 1.0 Bios: American Megatrends version: G551JM.202 date: 07/17/2014
CPU:  Quad core Intel Core i7-4710HQ CPU (-HT-MCP-) cache: 6144 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx)
  Clock Speeds: 1: 800.00 MHz 2: 2501.00 MHz 3: 800.00 MHz 4: 800.00 MHz 5: 800.00 MHz 6: 800.00 MHz 7: 800.00 MHz 8: 1200.00 MHz
Graphics:  Card: Intel 4th Gen Core Processor Integrated Graphics Controller
  X.Org: 1.15.1 driver: nvidia Resolution: [email protected], [email protected], [email protected]
  GLX Renderer: GeForce GTX 860M/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 352.09
Audio:  Card-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller driver: snd_hda_intel
  Card-2: Intel 8 Series/C220 Series Chipset High Definition Audio Controller driver: snd_hda_intel
  Sound: Advanced Linux Sound Architecture ver: k3.13.0-24-generic
Network:  Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
  IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Card-2: Intel Wireless 7260 driver: iwlwifi
  IF: wlan0 state: up mac: <filter>
Drives:  HDD Total Size: 500.1GB (54.7% used) 1: id: /dev/sda model: Samsung_SSD_850 size: 500.1GB
Partition: ID: / size: 459G used: 255G (59%) fs: ext4
RAID:  No RAID devices detected - /proc/mdstat and md_mod kernel raid module present
Sensors:  System Temperatures: cpu: 60.0C mobo: N/A gpu: 56C
  Fan Speeds (in rpm): cpu: N/A
Info:  Processes: 218 Uptime: 4:48 Memory: 3123.0/15492.2MB Client: Shell inxi: 1.8.4
TL;DR: xcomposite seems to have (at least) three related errors:
1. glXCreatePixmap failed: BadAlloc
2. glXCreatePixmap failed: BadMatch
3. device_copy_texture (GL) failed
If you error on "XCompositeNameWindowPixmap failed: BadMatch" your window is probably not active in your window manager and thus not rendering. (minimized or on another workspace or such)
I can repro some of the above, and have gdb (via qtcreator) just need guidance on how to get whatever info people need to quash this.
I had the exact same problem in June. But somehow it just disappeared by itself and works perfectly now. I don't know if Nvidia drivers fixed it (i always update to the latest ones as soon as they release new drivers, 355.06 currently in).
So i have no idea what actually fixed it. If i ever get the same bug and manage to fix it, i'll report back.
--snip--
Aww you got my hopes up... Mind providing some more system information? Or are you using the system in your signature at default settings? (aka, because sigs can change : ubuntu 15.04, gnome shell(?), gtx780)
I updated to the 355.06 drivers myself on my laptop, still no window capture. Info remains the same otherwise from my earlier post. Again I can reproduce easily with a debugger, if someone wants some more info let me know what to look at then...
Yes that's my rig. And it's official Ubuntu Gnome 15.04 so it comes with "ubuntu-gnome-desktop" (3.14) packages.
Now i get the bug again. Still haven't figured out what's the problem but i'm trying. It's seems pretty random. Nothing has changed since my last post.
When i launch obs from commandline, it gives this kind of error. Not sure if related.
error: xcompcap: XCompositeRedirectWindow failed: BadWindow (invalid Window parameter)
The XCompositeRedirectWindow: BadWindow generally means either (1) you don't have compositing available (unlikely) or (2) obs-studio has lost which window it is you are trying to capture, try re-selecting it from the drop-down-list. There are a few other causes but IIRC those are the most common.
