Question / Help OBS-Studio does not output video file
David Brown
Here is the log file.
Recordings do not render an output file. How do you solve this?
[dmbomer@deepcool ~]$ obs
Attempted path: share/obs/obs-studio/locale/en-US.ini
Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
Attempted path: share/obs/obs-studio/locale.ini
Attempted path: /usr/share/obs/obs-studio/locale.ini
Attempted path: share/obs/obs-studio/themes/Default.qss
Attempted path: /usr/share/obs/obs-studio/themes/Default.qss
Attempted path: share/obs/obs-studio/license/gplv2.txt
Attempted path: /usr/share/obs/obs-studio/license/gplv2.txt
info: Processor: 8 logical cores
info: Processor: AMD FX(tm)-8320 Eight-Core Processor
info: Physical Memory: 32145MB Total
info: Kernel Version: Linux 4.4.5-1-ARCH
info: Distribution: "Arch Linux" Unknown
QObject::connect: invalid null parameter
info: OBS 0.13.4-1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 44100
speakers: 2
info: OpenGL version: 3.2.0 NVIDIA 361.28
info: video settings reset:
base resolution: 1440x900
output resolution: 1152x720
fps: 30/1
format: NV12
info: Loading module: image-source.so
info: Loading module: linux-capture.so
info: Loading module: linux-decklink.so
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
info: No blackmagic support
info: Failed to start search for DeckLink devices
info: Loading module: linux-jack.so
info: Loading module: linux-pulseaudio.so
info: Loading module: linux-v4l2.so
info: Loading module: obs-ffmpeg.so
info: Loading module: obs-filters.so
info: Loading module: obs-libfdk.so
info: Loading module: obs-outputs.so
info: Loading module: obs-transitions.so
info: Loading module: obs-x264.so
info: Loading module: rtmp-services.so
info: Loading module: text-freetype2.so
info: =====================================================================
info: output 'simple_stream' (rtmp_output) created
info: encoder 'simple_h264_stream' (obs_x264) created
info: AAC encoder bitrate mapping:
32 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
64 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
96 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
128 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
160 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
192 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
224 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
256 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
288 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
320 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
info: encoder 'simple_aac' (libfdk_aac) created
info: encoder 'simple_h264_recording' (obs_x264) created
info: encoder 'simple_aac_recording' (libfdk_aac) created
info: output 'simple_file_output' (ffmpeg_muxer) created
info: service 'default_service' (rtmp_common) created
info: All scene data cleared
info: ------------------------------------------------
info: pulse-input: Server name: 'pulseaudio 8.0'
info: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
info: pulse-input: Started recording from 'alsa_input.pci-0000_00_14.2.analog-stereo'
info: source 'Mic/Aux' (pulse_input_capture) created
info: source 'Scene' (scene) created
info: xshm-input: Geometry 1440x900 @ 0,312
info: source 'Screen Capture (XSHM)' (xshm_input) created
info: == Profiler Results =============================
info: run_program_init: 475.657 ms
info: ┣OBSApp::AppInit: 3.259 ms
info: ┃ ┗OBSApp::InitLocale: 1.642 ms
info: ┗OBSApp::OBSInit: 388.269 ms
info: ┣obs_startup: 1.493 ms
info: ┗OBSBasic::OBSInit: 348.973 ms
info: ┣OBSBasic::InitBasicConfig: 0.513 ms
info: ┣OBSBasic::ResetAudio: 0.078 ms
info: ┣OBSBasic::ResetVideo: 168.966 ms
info: ┣OBSBasic::InitOBSCallbacks: 0.005 ms
info: ┣OBSBasic::InitHotkeys: 0.05 ms
info: ┣obs_load_all_modules: 19.785 ms
info: ┃ ┣obs_init_module(image-source.so): 0.002 ms
info: ┃ ┣obs_init_module(linux-capture.so): 0.669 ms
info: ┃ ┣obs_init_module(linux-decklink.so): 0.118 ms
info: ┃ ┣obs_init_module(linux-jack.so): 0.002 ms
info: ┃ ┣obs_init_module(linux-pulseaudio.so): 0.004 ms
info: ┃ ┣obs_init_module(linux-v4l2.so): 0.001 ms
info: ┃ ┣obs_init_module(obs-ffmpeg.so): 0.008 ms
info: ┃ ┣obs_init_module(obs-filters.so): 0.01 ms
info: ┃ ┣obs_init_module(obs-libfdk.so): 0.002 ms
info: ┃ ┣obs_init_module(obs-outputs.so): 0.003 ms
info: ┃ ┣obs_init_module(obs-transitions.so): 0.006 ms
info: ┃ ┣obs_init_module(obs-x264.so): 0.001 ms
info: ┃ ┣obs_init_module(rtmp-services.so): 0.102 ms
info: ┃ ┗obs_init_module(text-freetype2.so): 0.029 ms
info: ┣OBSBasic::ResetOutputs: 0.462 ms
info: ┣OBSBasic::CreateHotkeys: 0.026 ms
info: ┣OBSBasic::InitService: 0.052 ms
info: ┣OBSBasic::InitPrimitives: 53.144 ms
info: ┗OBSBasic::Load: 54.047 ms
info: Update check: last known remote version is 0.4.0
info: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
info: [x264 encoder: 'simple_h264_recording'] preset: veryfast
info: [x264 encoder: 'simple_h264_recording'] profile: high
info: [x264 encoder: 'simple_h264_recording'] settings:
bitrate: 1000
buffer size: 0
crf: 20
fps_num: 30
fps_den: 1
width: 1152
height: 720
keyint: 250
vfr: off
cbr: off
x264 [error]: high profile doesn't support a bit depth of 10
warning: [x264 encoder: 'simple_h264_recording'] Failed to set x264 profile 'high'
info: [x264 encoder: 'simple_h264_recording'] VBV maxrate specified, but no bufsize, ignored
info: libfdk_aac encoder created
info: libfdk_aac bitrate: 128, channels: 2
info: ==== Recording Start ===============================================
info: [ffmpeg muxer: 'simple_file_output'] Writing file '/home/dmbomer/Videos/Webcam/2016-04-02_20-38-41.mkv'...
info: [x264 encoder: 'simple_h264_recording'] This build of x264 requires high depth input. Rebuild to support 8-bit input.
warning: [x264 encoder: 'simple_h264_recording'] encode failed
error: Error encoding with encoder 'simple_h264_recording'
error: Called profile end with mismatching name: start("do_encode"[0x7fe9ef2bc1c1]) <-> end("receive_video"[0x7fe9ef2bc1b3])
info: libfdk_aac encoder destroyed
Couldn't initialize muxer
info: [ffmpeg muxer: 'simple_file_output'] Output of file '/home/dmbomer/Videos/Webcam/2016-04-02_20-38-41.mkv' stopped
info: Output 'simple_file_output': stopping
info: Output 'simple_file_output': Total encoded frames: 1042
info: Output 'simple_file_output': Total drawn frames: 1042
info: ==== Recording Stop ================================================
My attempts to resolve
removed both ffmpeg and ffmpeg2.8 and installed again no effect
removed obs-studio and installed different version from AUR no effect
Simple mode just wouldn't create a file
however advanced mode started working I don't know why.
