OBS Studio Crashing on Startup via Mac Pro
HulaHeart
Anytime I open OBS Studio it'll just give me an error message saying it crashed. I tried uninstalling and reinstalling multiple times, but doesn't seem to work.
I am just using OBS Studio to capture my screen while my PC laptop is streaming the content. Thanks for your help!
This is the error code that I receive.
Process: obs [560] Path: /Applications/OBS.app/Contents/MacOS/obs Identifier: com.obsproject.obs-studio Version: 27.2.4 (27.2.4) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: obs [560] User ID: 501 Date/Time: 2022-04-10 12:20:52.417 -0700 OS Version: Mac OS X 10.14.6 (18G9323) Report Version: 12 Anonymous UUID: 234D8F12-E2BD-1879-6FB0-9D5715A37B64 Time Awake Since Boot: 68 seconds System Integrity Protection: enabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Termination Reason: DYLD, [0x4] Symbol missing Dyld Error Message: Symbol not found: _aligned_alloc Referenced from: /Library/Application Support/obs-studio/*/loupedeck-obs.so (which was built for Mac OS X 11.6) Expected in: /usr/lib/libSystem.B.dylib Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 dyld 0x0000000103b2b3ba __abort_with_payload + 10 1 dyld 0x0000000103b2abac abort_with_payload_wrapper_internal + 82 2 dyld 0x0000000103b2abde abort_with_payload + 9 3 dyld 0x0000000103aeaa9d dyld::halt(char const*) + 343 4 dyld 0x0000000103aeabc7 dyld::fastBindLazySymbol(ImageLoader**, unsigned long) + 167 5 libdyld.dylib 0x00007fff7717b32e dyld_stub_binder + 282 6 ??? 0x000000011783f270 0 + 4689490544 7 loupedeck-obs.so 0x00000001177c4ade void asio::detail::reactive_socket_service<asio::ip::tcp>::async_accept<asio::basic_socket<asio::ip::tcp, asio::any_io_executor>, asio::detail::wrapped_handler<asio::io_context::strand, std::__1::__bind<void (websocketpp::transport::asio::endpoint<websocketpp::config::asio::transport_config>::*)(std::__1::function<void (std::__1::error_code const&)>, std::__1::error_code const&), websocketpp::transport::asio::endpoint<websocketpp::config::asio::transport_config>*, std::__1::function<void (std::__1::error_code const&)>&, std::__1::placeholders::__ph<1> const&>, asio::detail::is_continuation_if_running>, asio::any_io_executor>(asio::detail::reactive_socket_service<asio::ip::tcp>::implementation_type&, asio::basic_socket<asio::ip::tcp, asio::any_io_executor>&, asio::ip::basic_endpoint<asio::ip::tcp>*, asio::detail::wrapped_handler<asio::io_context::strand, std::__1::__bind<void (websocketpp::transport::asio::endpoint<websocketpp::config::asio::transport_config>::*)(std::__1::function<void (std::__1::error_code const&)>, std::__1::error_code const&), websocketpp::transport::asio::endpoint<websocketpp::config::asio::transport_config>*, std::__1::function<void (std::__1::error_code const&)>&, std::__1::placeholders::__ph<1> const&>, asio::detail::is_continuation_if_running>&, asio::any_io_executor const&) + 158 8 loupedeck-obs.so 0x00000001177ad552 websocketpp::transport::asio::endpoint<websocketpp::config::asio::transport_config>::async_accept(std::__1::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::asio::transport_config> >, std::__1::function<void (std::__1::error_code const&)>, std::__1::error_code&) + 466 9 loupedeck-obs.so 0x00000001177ad131 websocketpp::server<websocketpp::config::asio>::start_accept(std::__1::error_code&) + 257 10 loupedeck-obs.so 0x00000001177a18ca websocketpp::server<websocketpp::config::asio>::start_accept() + 42 11 loupedeck-obs.so 0x00000001177a1744 WSServer::start(unsigned short, bool) + 788 12 loupedeck-obs.so 0x000000011779edf8 obs_module_load::$_1::__invoke(obs_frontend_event, void*) + 40 13 com.obsproject.obs-studio 0x0000000101548f0f OBSStudioAPI::on_event(obs_frontend_event) + 111 14 com.obsproject.obs-studio 0x00000001015615f1 OBSBasic::OBSInit() + 4961 15 com.obsproject.obs-studio 0x000000010153a707 OBSApp::OBSInit() + 727 16 com.obsproject.obs-studio 0x000000010153f2ac main + 5212 17 libdyld.dylib 0x00007fff7718f3d5 start + 1 Model: MacPro5,1, BootROM 144.0.0.0.0, 12 processors, 6-Core Intel Xeon, 3.33 GHz, 96 GB, SMC 1.39f5 Graphics: AMD Radeon HD 7950, AMD Radeon HD 7950, spdisplays_pcie_device, 3 GB Memory Module: DIMM 1, 16 GB, DDR3 ECC, 1333 MHz, 0x80CE, 0x4D3339324232473730424D302D5948392020 Memory Module: DIMM 2, 16 GB, DDR3 ECC, 1333 MHz, 0x80CE, 0x4D3339324232473730424D302D5948392020 Memory Module: DIMM 3, 16 GB, DDR3 ECC, 1333 MHz, 0x80CE, 0x4D3339324232473730424D302D5948392020 Memory Module: DIMM 5, 16 GB, DDR3 ECC, 1333 MHz, 0x80CE, 0x4D3339324232473730424D302D5948392020 Memory Module: DIMM 6, 16 GB, DDR3 ECC, 1333 MHz, 0x80CE, 0x4D3339324232473730424D302D5948392020 Memory Module: DIMM 7, 16 GB, DDR3 ECC, 1333 MHz, 0x80CE, 0x4D3339324232473730424D302D5948392020 AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.102.31) Bluetooth: Version 6.0.14d13, 3 services, 27 devices, 1 incoming serial ports Network Service: Ethernet 1, Ethernet, en0 PCI Card: AMD Radeon HD 7950, Display Controller, Slot-1 PCI Card: AMD Radeon HD 7950, ATY,HamachiParent, Slot-1 PCI Card: PXS4, USB eXtensible Host Controller, Slot-4 Serial ATA Device: HL-DT-ST DVD-RW GH61N Serial ATA Device: HUA722020ALA330, 2 TB Serial ATA Device: WDC WDS100T2B0A-00SM50, 1 TB Serial ATA Device: WDC WD2003FZEX-00SRLA0, 2 TB USB Device: USB 2.0 Bus USB Device: USB 2.0 Bus USB Device: USB Bus USB Device: USB Bus USB Device: 2.4G Keyboard Mouse USB Device: USB Bus USB Device: BRCM2046 Hub USB Device: Bluetooth USB Host Controller USB Device: USB Bus USB Device: USB Bus USB Device: USB Bus USB Device: Razer BlackWidow Elite USB Device: USB 3.0 Bus FireWire Device: built-in_hub, Up to 800 Mb/sec Thunderbolt Bus:
