OBS Studio 30.1 crashes on Mac OS when removing a source from a scene
JakeMTL
Issue:
I noticed that OBS Studio 30.1 crashes consistently on Mac OS when removing a source from a scene, and prompts a report to MAC. This happens with both macOS Sonoma 14.3 and 14.4.
Workaround:
In case it is helpful for others, the work around is the following: The behavior is not repeated in safe mode, and you can therefore remove sources in safe mode without experiencing the crashing behavior, and then continue to open OBS in regular mode to continue using the application.
Hello @pcbolix
I found the issue and the solution. It appears that the issue stems from Elgato Stream Deck and not OBS. I installed the update and the issue is resolved.
My apologies to the wonderful OBS developement team for misdiagnosing this issue as a bug with 30.1. It was shown to be an issue with a 3rd party software.
