OBS not Opening
ReikoLupus
Salutations, I'm having a little bit of a problem.
2 Weeks ago Sunday 26/04, I had my last Stream before, after going to do so again days later, OBS wouldn't open anymore.
I have tried uninstalling and re-installing it, even deleting my local files and configurations, but every time I try to open it, be it through the Application Launcher or through Bazaar, nothing would happen. The closest thing to something happening is, if I do it from the Application Launcher, the little symbol of OBS would appear to the right of the mouse as if it was trying to open, but disappear a few seconds afterwards with it never opening.
Looking into the current version through Bazaar, it says that Version 32.1.2 came out 2 weeks ago, so it could have something to do with me suddenly being unable to use it.
I'm using Bazzite, having moved to Linux just 3~ months ago, so there's still a lot about how to solve problems here that I may not know. I have tried many things I thought and read, but either I did them wrong or it achieved nothing.
Does someone have some idea of what I could do to try to fix this?
There might have been an update within Flatpak that's causing problems, just like it did for me. My solution was to first run the command "flatpak run com.obsproject.Studio "to see what the problem is, then I disabled and re-enabled X11 in Flatseal, and after that it seemed to work, or type flatpak override --user --socket=x11 com.obsproject.Studio
if you see after running the first command errors you can ask Ai to see what help it can give
