keith.finnie
Just upgraded from 20.04 to 22.04. Otherwise, no changes to previously working setup.
Started OBS from command line and here are the results:
Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
QSocketNotifier: Can only be used with threads started with QThread
debug: Found portal inhibitor
debug: Attempted path: share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale.ini
debug: Attempted path: share/obs/obs-studio/locale/en-GB.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-GB.ini
info: Using preferred locale 'en-GB'
debug: Attempted path: share/obs/obs-studio/themes/Yami.qss
debug: Attempted path: /usr/share/obs/obs-studio/themes/Yami.qss
info: Platform: Wayland
info: CPU Name: Intel(R) Core(TM) i3-3240 CPU @ 3.40GHz
info: CPU Speed: 1639.339MHz
info: Physical Cores: 2, Logical Cores: 4
info: Physical Memory: 5805MB Total, 2531MB Free
info: Kernel Version: Linux 5.15.0-122-generic
info: Distribution: "Ubuntu" "22.04"
info: Desktop Environment: ubuntu:GNOME (ubuntu)
info: Session Type: wayland
info: Qt Version: 5.15.3 (runtime), 5.12.8 (compiled)
info: Portable mode: false
QMetaObject::connectSlotsByName: Connecting slot on_transitionDuration_valueChanged() with the first of the following compatible signals: ("valueChanged(int)", "valueChanged(QString)")
info: OBS 29.1.3 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 48000
speakers: 2
max buffering: 960 milliseconds
buffering type: dynamically increasing
info: Initializing OpenGL...
info: Using EGL/Wayland
info: Initialized EGL 1.5
info: Loading up OpenGL on adapter Intel Mesa Intel(R) HD Graphics 2500 (IVB GT1)
info: OpenGL loaded successfully, version 4.2 (Core Profile) Mesa 23.2.1-1ubuntu3.1~22.04.2, shading language 4.20
info: video settings reset:
base resolution: 1920x1080
output resolution: 1280x720
downscale filter: Bicubic
fps: 30/1
format: NV12
YUV mode: Rec. 709/Partial
info: NV12 texture support not available
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-GB' text for module: 'aja-output-ui.so'
warning: No AJA devices found, skipping loading AJA UI plugin
warning: Failed to initialize module 'aja-output-ui.so'
warning: Failed to load 'en-GB' text for module: 'aja.so'
warning: No AJA devices found, skipping loading AJA plugin
warning: Failed to initialize module 'aja.so'
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
warning: Failed to load 'en-GB' text for module: 'frontend-tools.so'
warning: Failed to load 'en-GB' text for module: 'linux-alsa.so'
warning: Failed to load 'en-GB' text for module: 'linux-capture.so'
warning: Failed to load 'en-GB' text for module: 'linux-jack.so'
warning: Failed to load 'en-GB' text for module: 'linux-pulseaudio.so'
info: [obs-browser]: Version 2.21.1
info: [obs-browser]: CEF Version 103.0.5060.134 (runtime), 103.0.0-5060-shared-textures_143.2591+g4204d54+chromium-103.0.5060.134 (compiled)
info: VAAPI: API version 1.14
info: FFmpeg VAAPI H264 encoding supported
info: FFmpeg VAAPI HEVC encoding not supported
warning: Failed to load 'en-GB' text for module: 'obs-libfdk.so'
warning: Failed to load 'en-GB' text for module: 'obs-vst.so'
warning: Failed to load 'en-GB' text for module: 'obs-websocket.so'
info: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.2.3 | RPC Version: 1)
info: [obs-websocket] [obs_module_load] Qt version (compile-time): 5.12.8 | Qt version (run-time): 5.15.3
info: [obs-websocket] [obs_module_load] Linked ASIO Version: 101202
info: [obs-websocket] [obs_module_load] Module loaded.
warning: Failed to load 'en-GB' text for module: 'rtmp-services.so'
info: [vlc-video]: VLC 3.0.16 Vetinari found, VLC video source enabled
info: Loaded Modules:
info: vlc-video.so
info: text-freetype2.so
info: rtmp-services.so
info: obs-x264.so
info: obs-websocket.so
info: obs-vst.so
info: obs-transitions.so
info: obs-outputs.so
info: obs-libfdk.so
info: obs-filters.so
info: obs-ffmpeg.so
info: obs-browser.so
info: linux-v4l2.so
info: linux-pulseaudio.so
info: linux-jack.so
info: linux-capture.so
info: linux-alsa.so
info: image-source.so
info: frontend-tools.so
info: decklink-output-ui.so
info: decklink-captions.so
QWidget::setTabOrder: 'first' and 'second' must be in the same window
info: ==== Startup complete ===============================================
info: All scene data cleared
info: ------------------------------------------------
info: pulse-input: Server name: 'pulseaudio 15.99.1'
info: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
info: pulse-input: Started recording from 'auto_null.monitor' (default)
info: pulse-am: Prevented feedback-loop in 'default'
info: [Loaded global audio device]: 'Desktop Audio'
info: - monitoring: monitor and output
info: [Media Source 'Camera1']: settings:
input: rtsp://admin:[email protected]:554/h264Preview_01_sub
input_format:
speed: 100
is_looping: no
is_linear_alpha: no
is_hw_decoding: no
is_clear_on_media_end: no
restart_on_activate: no
close_when_inactive: no
full_decode: no
ffmpeg_options:
info: pulse-am: Server name: 'pulseaudio 15.99.1'
info: pulse-am: Audio format: s16le, 44100 Hz, 2 channels
info: pulse-am: Started Monitoring in 'auto_null'
info: [Media Source 'Camera 2']: settings:
input_format:
speed: 100
is_looping: no
is_linear_alpha: no
is_hw_decoding: no
full_decode: no
ffmpeg_options:
info: Switched to scene 'Scene'
info: Loaded scenes:
info: - scene 'Scene':
info: - source: 'Camera1' (ffmpeg_source)
info: - source: 'Camera 2' (ffmpeg_source)
[udp @ 0x7fd31c00c080] attempted to set receive buffer to size 4194304 but it only ended up set as 425984
[udp @ 0x7fd31c01c3c0] attempted to set receive buffer to size 4194304 but it only ended up set as 425984
[udp @ 0x7fd33400c680] attempted to set receive buffer to size 4194304 but it only ended up set as 425984
[udp @ 0x7fd33400c200] attempted to set receive buffer to size 4194304 but it only ended up set as 425984
[udp @ 0x7fd31c02d700] attempted to set receive buffer to size 4194304 but it only ended up set as 425984
[udp @ 0x7fd31c00b840] attempted to set receive buffer to size 4194304 but it only ended up set as 425984
[udp @ 0x7fd33402db80] attempted to set receive buffer to size 4194304 but it only ended up set as 425984
[udp @ 0x7fd33402d5c0] attempted to set receive buffer to size 4194304 but it only ended up set as 425984
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
info: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Desktop Audio)
info: [x264 encoder: 'simple_video_stream'] preset: veryfast
info: [x264 encoder: 'simple_video_stream'] settings:
rate_control: CBR
bitrate: 2500
buffer size: 2500
crf: 0
fps_num: 30
fps_den: 1
width: 1280
height: 720
keyint: 60
Segmentation fault (core dumped)
Thanks in advance.
Keith
speakers: 2
fps: 30/1
format: NV12
info: vlc-video.so
info: obs-x264.so
info: obs-vst.so
info: obs-libfdk.so
info: obs-ffmpeg.so
info: linux-v4l2.so
info: linux-jack.so
info: linux-alsa.so
input_format:
speed: 100
is_looping: no
is_linear_alpha: no
is_hw_decoding: no
full_decode: no
ffmpeg_options:
input_format:
speed: 100
is_looping: no
is_linear_alpha: no
is_hw_decoding: no
full_decode: no
ffmpeg_options:
rate_control: CBR
bitrate: 2500
buffer size: 2500
crf: 0
fps_num: 30
fps_den: 1
width: 1280
height: 720
keyint: 60
Thanks in advance.
Keith
