OBS crash while streaming BG3
So whenever I'm streaming BG3 OBS seems to have some kind of issues that make the program lag or even crash. When I click away from the game and onto the second monitor where I have OBS and all the other programs sitting it returns to normal, I have no idea what's causing it and am thoroughly confused since it doesn't happen with other games and OBS seems to keep running despite it being in the middle of a crash.
  • Crash 2026-10-02 20-24-02.txt
  • Crash 2026-10-03 00-47-49.txt
  • Crash 2026-10-03 11-08-24.txt
  • Crash 2026-11-06 21-49-42.txt
This is an issue with a browser source and/or dock. Make sure that you are using the newest version of OBS and that any plugins are compatible with that version and are up-to-date.
If still having issues, re-open OBS after it crashes and provide the previous log file and the crash file.
I ran obs after the stream since it closed OBS fully as I was ending the stream and talking to the community so I reopened it and finished it out. So I'm not sure if I would still have access to that log via URL. I have the logs that were created from that day I can upload to the website.
1. The Hardware-accelerated GPU scheduling ("HAGS") feature added in Windows is currently known to cause issues with OBS, games and overlay tools. We recommend disabling it via this screen or these instructions as a troubleshooting step. Be sure to restart after disabling it.
2. Multiple Game Capture sources are usually not needed, and can sometimes interfere with each other (Game captures and Gaming). You can use the same Game Capture for all your games. If you change games often, try out the hotkey mode, which lets you press a key to select your active game. If you play games in fullscreen, use 'Capture any fullscreen application' mode.
3. Make sure that all of your plugins are compatible with OBS 33.0.1
4. Create a new scene collection with just one Game Capture source; nothing else. Close and restart OBS.
If still happening, this would indicate an issue with a browser dock. If not happening, that would indicate the issue was caused by a browser source.
I've disabled the HAGS feature and haven't noticed anything happening just yet with the docks whiting/blacking out. The reason for so many game capture sources is because I also stream to vertical and some games have a layout that can look good in vertical formatting and I use source clone in order to create those extra sources in my vertical format where I then apply mask filters to get just the part I want. So I need a reliable source I can pull from over to the vertical format where I can apply said mask filter
