The recording with CQP (for example) to a local file is different for "no reason".
The point is that the QuickSync recording is not usable in Adobe Premiere Pro but it works very well in Vegas Pro 15/16. The NVENC recording is flawless in that case.
There is surely something different in terms of H264 Encoder-Settings. Sadly you cannot change anything in OBS.
Can you make the QuickSync recording like the NVENC please?! Remuxing does not fix the problem. Re-Encoding sure, but there is a big quality and time loss with that. Talking about 100-200 GB Files.
Would be great to see this! There must be a small difference between QuickSync and NVENC, I am sure. But there is no need to be so.
Can you post OBS logs, media info, and sample files (to a file sharing site) for both a file recorded via QuickSync and a file recorded via NVEnc where this problem happens, using as similar settings between the two as possible?
I recorded the files with NVENC and QuickSync (by name u can tell). Going for both recordings with high quality preset and CQP as quality control. Using "main" as profile does not change anything, I have already tested this of course.
The QuickSync recording remains incompatible with ADOBE PREMIERE PRO!
Sample Files go here (it is funny how the QuickSync recording does not provide thumbnails there but the NVENC does).
General
Complete name : E:\xRECORDING\NVENC.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 896 MiB
Duration : 3 min 23 s
Overall bit rate mode : Variable
Overall bit rate : 36.9 Mb/s
Writing application : Lavf57.84.100
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, RefFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 36.6 Mb/s
Maximum bit rate : 120 Mb/s
Width : 2 560 pixels
Height : 1 440 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.166
Stream size : 889 MiB (99%)
Color range : Limited
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Bit rate : 265 kb/s
Maximum bit rate : 320 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 6.33 MiB (1%)
Title : Track2
Default : Yes
Alternate group : 1
#### OBS ####
03:10:31.892: CPU Name: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
03:10:31.892: CPU Speed: 3696MHz
03:10:31.892: Physical Cores: 6, Logical Cores: 12
03:10:31.892: Physical Memory: 16257MB Total, 14236MB Free
03:10:31.892: Windows Version: 10.0 Build 14393 (revision: 693; 64-bit)
03:10:31.892: Running as administrator: true
03:10:31.892: Aero is Enabled (Aero is always on for windows 8 and above)
03:10:31.892: Windows 10 Gaming Features:
03:10:31.892: Game DVR: Off
03:10:31.896: Sec. Software Status:
03:10:31.898: Portable mode: false
03:10:31.984: OBS 21.1.2 (64bit, windows)
03:10:31.984: ---------------------------------
03:10:31.985: ---------------------------------
03:10:31.985: audio settings reset:
03:10:31.985: samples per sec: 48000
03:10:31.985: speakers: 2
03:10:31.988: ---------------------------------
03:10:31.988: Initializing D3D11...
03:10:31.988: Available Video Adapters:
03:10:31.989: Adapter 1: NVIDIA GeForce GTX 1080 Ti
03:10:31.989: Dedicated VRAM: 3084836864
03:10:31.989: Shared VRAM: 4228683776
03:10:31.989: output 1: pos={0, 0}, size={2560, 1440}, attached=true
03:10:31.989: Adapter 2: Intel(R) UHD Graphics 630
03:10:31.989: Dedicated VRAM: 134217728
03:10:31.996: Loading up D3D11 on adapter NVIDIA GeForce GTX 1080 Ti (0)
03:10:32.099: D3D11 loaded successfully, feature level used: 45056
03:10:32.657: ---------------------------------
03:10:32.657: video settings reset:
03:10:32.657: base resolution: 2560x1440
03:10:32.657: output resolution: 2560x1440
03:10:32.657: downscale filter: Lanczos
03:10:32.657: fps: 60/1
03:10:32.657: format: NV12
03:10:32.657: YUV mode: 709/Partial
03:10:32.658: Audio monitoring device:
03:10:32.658: name: Default
03:10:32.658: id: default
03:10:32.658: ---------------------------------
03:10:32.662: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
03:10:32.681: [AMF] AMF Test failed due to one or more errors.
03:10:32.681: Failed to initialize module 'enc-amf.dll'
03:10:32.712: NVENC supported
03:10:32.756: VLC found, VLC video source enabled
03:10:32.760: No blackmagic support
03:10:32.773: ---------------------------------
03:10:32.773: Loaded Modules:
03:10:32.773: win-wasapi.dll
03:10:32.773: win-mf.dll
03:10:32.773: win-dshow.dll
03:10:32.773: win-decklink.dll
03:10:32.773: win-capture.dll
03:10:32.773: vlc-video.dll
03:10:32.773: text-freetype2.dll
03:10:32.773: rtmp-services.dll
03:10:32.773: obs-x264.dll
03:10:32.773: obs-vst.dll
03:10:32.773: obs-transitions.dll
03:10:32.773: obs-text.dll
03:10:32.773: obs-qsv11.dll
03:10:32.773: obs-outputs.dll
03:10:32.773: obs-filters.dll
03:10:32.773: obs-ffmpeg.dll
03:10:32.773: image-source.dll
03:10:32.773: frontend-tools.dll
03:10:32.773: enc-amf.dll
03:10:32.773: coreaudio-encoder.dll
03:10:32.773: ==== Startup complete ===============================================
03:10:32.777: All scene data cleared
03:10:32.777: ------------------------------------------------
03:10:32.804: WASAPI: Device 'Lautsprecher (ASUS Xonar DGX Audio Device)' initialized
03:10:32.816: WASAPI: Device 'Mikrofon (ASUS Xonar DGX Audio Device)' initialized
03:10:32.816: source 'Mic/Aux' enabled push-to-talk
03:10:32.827: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds
03:10:33.179: Switched to scene 'STD'
03:10:33.179: ------------------------------------------------
03:10:33.179: Loaded scenes:
03:10:33.179: - scene 'STD':
03:10:33.179: - source: 'DOSII' (game_capture)
03:10:33.179: - source: 'MGSV' (game_capture)
03:10:36.206: adding 21 milliseconds of audio buffering, total audio buffering is now 42 milliseconds
03:10:44.258: [game-capture: 'DOSII'] attempting to hook process: EoCApp.exe
03:10:44.260: [game-capture: 'DOSII'] using helper (compatibility hook)
03:10:44.262: [game-capture: 'DOSII'] hook not loaded yet, retrying..
03:10:47.275: [game-capture: 'DOSII'] attempting to hook process: EoCApp.exe
03:10:47.302: [game-capture: 'DOSII'] d3d11 shared texture capture successful
03:10:47.308: [game-capture: 'DOSII'] shared texture capture successful
03:11:36.235: ---------------------------------
03:11:36.237: [NVENC encoder: 'recording_h264'] settings:
03:11:36.237: rate_control: CQP
03:11:36.237: bitrate: 0
03:11:36.237: cqp: 16
03:11:36.237: keyint: 250
03:11:36.237: preset: hq
03:11:36.237: profile: high
03:11:36.237: level: auto
03:11:36.237: width: 2560
03:11:36.237: height: 1440
03:11:36.237: 2-pass: true
03:11:36.237: b-frames: 2
03:11:36.237: GPU: 0
03:11:36.237:
03:11:36.482: ---------------------------------
03:11:36.482: [FFmpeg aac encoder: 'Track2'] bitrate: 320, channels: 2, channel_layout: 3
03:11:36.482:
03:11:36.538: ==== Recording Start ===============================================
03:11:36.538: [ffmpeg muxer: 'adv_file_output'] Writing file 'E:/xRECORDING/2018-10-04_03-11-36.mp4'...
03:14:11.486: Stopping recording due to hotkey
03:14:11.748: [ffmpeg muxer: 'adv_file_output'] Output of file 'E:/xRECORDING/2018-10-04_03-11-36.mp4' stopped
03:14:11.748: Output 'adv_file_output': stopping
03:14:11.748: Output 'adv_file_output': Total frames output: 9300
03:14:11.748: Output 'adv_file_output': Total drawn frames: 9313
03:14:11.748: ==== Recording Stop ================================================
03:14:37.725: [game-capture: 'DOSII'] capture stopped
03:14:38.258: [game-capture: 'DOSII'] attempting to hook process: EoCApp.exe
03:14:38.275: [game-capture: 'DOSII'] capture stopped
03:14:41.275: [game-capture: 'DOSII'] attempting to hook process: EoCApp.exe
03:14:41.292: [game-capture: 'DOSII'] capture stopped
03:14:44.292: [game-capture: 'DOSII'] attempting to hook process: EoCApp.exe
03:14:44.308: [game-capture: 'DOSII'] capture stopped
03:14:47.308: [game-capture: 'DOSII'] attempting to hook process: EoCApp.exe
03:14:47.325: [game-capture: 'DOSII'] capture stopped
03:14:50.325: [game-capture: 'DOSII'] attempting to hook process: EoCApp.exe
03:14:50.342: [game-capture: 'DOSII'] capture stopped
03:15:17.475: [game-capture: 'DOSII'] attempting to hook process: EoCApp.exe
03:15:17.476: [game-capture: 'DOSII'] using helper (compatibility hook)
03:15:17.477: [game-capture: 'DOSII'] hook not loaded yet, retrying..
03:15:20.492: [game-capture: 'DOSII'] attempting to hook process: EoCApp.exe
03:15:20.501: [game-capture: 'DOSII'] d3d11 shared texture capture successful
03:15:20.508: [game-capture: 'DOSII'] shared texture capture successful
03:15:43.244: ---------------------------------
03:15:43.244: [NVENC encoder: 'recording_h264'] settings:
03:15:43.244: rate_control: CQP
03:15:43.244: bitrate: 0
03:15:43.244: cqp: 16
03:15:43.244: keyint: 250
03:15:43.244: preset: hq
03:15:43.244: profile: high
03:15:43.244: level: auto
03:15:43.244: width: 2560
03:15:43.244: height: 1440
03:15:43.244: 2-pass: true
03:15:43.244: b-frames: 2
03:15:43.244: GPU: 0
03:15:43.244:
03:15:43.379: ---------------------------------
03:15:43.379: [FFmpeg aac encoder: 'Track2'] bitrate: 320, channels: 2, channel_layout: 3
03:15:43.379:
03:15:43.383: ==== Recording Start ===============================================
03:15:43.383: [ffmpeg muxer: 'adv_file_output'] Writing file 'E:/xRECORDING/2018-10-04_03-15-43.mp4'...
03:19:07.065: Stopping recording due to hotkey
03:19:07.331: [ffmpeg muxer: 'adv_file_output'] Output of file 'E:/xRECORDING/2018-10-04_03-15-43.mp4' stopped
03:19:07.331: Output 'adv_file_output': stopping
03:19:07.331: Output 'adv_file_output': Total frames output: 12224
03:19:07.331: Output 'adv_file_output': Total drawn frames: 12237
03:19:07.331: ==== Recording Stop ================================================
General
Complete name : E:\xRECORDING\QuickSync.mp4
Format : MPEG-4
File size : 837 MiB
Duration : 3 min 49 s
Overall bit rate : 30.5 Mb/s
Video
Format : AVC
Format settings, RefFrames : 3 frames
Codec ID : avc1
Bit rate : 30.2 Mb/s
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.137
Stream size : 829 MiB (99%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Bit rate : 288 kb/s
Stream size : 7.88 MiB (1%)
Title : Track2
Default : Yes
Alternate group : 1
#### OBS ####
03:22:09.667: Settings changed (outputs)
03:22:09.667: ------------------------------------------------
03:22:13.959: [qsv encoder: 'recording_h264'] settings:
03:22:13.959: rate_control: CQP
03:22:13.959: qpi: 23
03:22:13.959: qpb: 23
03:22:13.959: qpp: 23
03:22:13.959: fps_num: 60
03:22:13.959: fps_den: 1
03:22:13.959: width: 2560
03:22:13.959: height: 1440
03:22:13.959: [qsv encoder: 'recording_h264'] debug info:
03:22:13.964: impl: D3D11
03:22:13.964: surf: D3D11
03:22:14.045: m_nSurfNum: 19
03:22:14.049: m_nTaskPool: 4
03:22:14.049: major: 1
03:22:14.049: minor: 27
03:22:14.049: ---------------------------------
03:22:14.049: [FFmpeg aac encoder: 'Track2'] bitrate: 320, channels: 2, channel_layout: 3
03:22:14.049:
03:22:14.392: ==== Recording Start ===============================================
03:22:14.392: [ffmpeg muxer: 'adv_file_output'] Writing file 'E:/xRECORDING/2018-10-04_03-22-13.mp4'...
03:26:04.251: Stopping recording due to hotkey
03:26:04.712: [ffmpeg muxer: 'adv_file_output'] Output of file 'E:/xRECORDING/2018-10-04_03-22-13.mp4' stopped
03:26:04.712: Output 'adv_file_output': stopping
03:26:04.712: Output 'adv_file_output': Total frames output: 13795
03:26:04.712: Output 'adv_file_output': Total drawn frames: 13819
03:26:04.712: ==== Recording Stop ================================================
03:26:04.713: Video stopped, number of skipped frames due to encoding lag: 19/13820 (0.1%)
03:26:07.907: [game-capture: 'DOSII'] capture window no longer exists, terminating capture
03:26:07.907: [game-capture: 'DOSII'] capture stopped
03:27:55.689: Settings changed (outputs)
03:27:55.689: ------------------------------------------------
03:28:01.866: ==== Shutting down ==================================================
03:28:01.868: Switched to scene '(null)'
03:28:01.868: WASAPI: Device 'Lautsprecher (ASUS Xonar DGX Audio Device)' Terminated
03:28:01.873: WASAPI: Device 'Mikrofon (ASUS Xonar DGX Audio Device)' Terminated
03:28:01.875: All scene data cleared
03:28:01.875: ------------------------------------------------
03:28:01.907: Freeing OBS context data
03:28:01.919: [Scripting] Total detached callbacks: 0
03:28:01.926: == Profiler Results =============================
03:28:01.926: run_program_init: 1634.6 ms
03:28:01.926: ┣OBSApp::AppInit: 10.825 ms
03:28:01.926: ┃ ┗OBSApp::InitLocale: 2.158 ms
03:28:01.926: ┗OBSApp::OBSInit: 1579.75 ms
03:28:01.926: ┣obs_startup: 7.564 ms
03:28:01.926: ┗OBSBasic::OBSInit: 1225.84 ms
03:28:01.926: ┣OBSBasic::InitBasicConfig: 0.289 ms
03:28:01.926: ┣OBSBasic::ResetAudio: 0.272 ms
03:28:01.926: ┣OBSBasic::ResetVideo: 673.242 ms
03:28:01.926: ┣OBSBasic::InitOBSCallbacks: 0.007 ms
03:28:01.926: ┣OBSBasic::InitHotkeys: 0.249 ms
03:28:01.926: ┣obs_load_all_modules: 114.522 ms
03:28:01.926: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.291 ms
03:28:01.926: ┃ ┣obs_init_module(enc-amf.dll): 15.493 ms
03:28:01.926: ┃ ┣obs_init_module(frontend-tools.dll): 3.183 ms
03:28:01.926: ┃ ┣obs_init_module(image-source.dll): 0.003 ms
03:28:01.926: ┃ ┣obs_init_module(obs-ffmpeg.dll): 10.943 ms
03:28:01.926: ┃ ┃ ┗nvenc_check: 10.91 ms
03:28:01.926: ┃ ┣obs_init_module(obs-filters.dll): 0.007 ms
03:28:01.926: ┃ ┣obs_init_module(obs-outputs.dll): 0.003 ms
03:28:01.926: ┃ ┣obs_init_module(obs-qsv11.dll): 14.785 ms
03:28:01.926: ┃ ┣obs_init_module(obs-text.dll): 0.758 ms
03:28:01.926: ┃ ┣obs_init_module(obs-transitions.dll): 0.004 ms
03:28:01.926: ┃ ┣obs_init_module(obs-vst.dll): 0.001 ms
03:28:01.926: ┃ ┣obs_init_module(obs-x264.dll): 0.001 ms
03:28:01.926: ┃ ┣obs_init_module(rtmp-services.dll): 0.164 ms
03:28:01.926: ┃ ┣obs_init_module(text-freetype2.dll): 0.259 ms
03:28:01.926: ┃ ┣obs_init_module(vlc-video.dll): 6.492 ms
03:28:01.926: ┃ ┣obs_init_module(win-capture.dll): 0.063 ms
03:28:01.926: ┃ ┣obs_init_module(win-decklink.dll): 1.424 ms
03:28:01.926: ┃ ┣obs_init_module(win-dshow.dll): 2.555 ms
03:28:01.926: ┃ ┣obs_init_module(win-mf.dll): 0 ms
03:28:01.926: ┃ ┣obs_init_module(win-wasapi.dll): 0.003 ms
03:28:01.926: ┃ ┗reset_win32_symbol_paths: 5.041 ms
03:28:01.926: ┣OBSBasic::ResetOutputs: 0.291 ms
03:28:01.926: ┣OBSBasic::CreateHotkeys: 0.135 ms
03:28:01.926: ┣OBSBasic::InitService: 1.832 ms
03:28:01.926: ┣OBSBasic::InitPrimitives: 0.439 ms
03:28:01.926: ┗OBSBasic::Load: 403.02 ms
03:28:01.926: obs_hotkey_thread(25 ms): min=0.001 ms, median=0.003 ms, max=28.003 ms, 99th percentile=0.035 ms, 99.9976% below 25 ms
03:28:01.926: audio_thread(Audio): min=0 ms, median=0.382 ms, max=41.538 ms, 99th percentile=2.747 ms
03:28:01.926: ┗receive_audio: min=0.002 ms, median=0.873 ms, max=41.505 ms, 99th percentile=2.627 ms, 0.549086 calls per parent call
03:28:01.926: ┣buffer_audio: min=0 ms, median=0.001 ms, max=0.045 ms, 99th percentile=0.002 ms
03:28:01.926: ┗do_encode: min=0.01 ms, median=0.869 ms, max=41.501 ms, 99th percentile=2.624 ms
03:28:01.926: ┣encode(Track2): min=0.01 ms, median=1.053 ms, max=4.813 ms, 99th percentile=2.558 ms, 0.608316 calls per parent call
03:28:01.926: ┗encode(Track2): min=0.013 ms, median=0.549 ms, max=4.174 ms, 99th percentile=2.62 ms, 0.391684 calls per parent call
03:28:01.926: obs_graphics_thread(16.6667 ms): min=0.187 ms, median=0.819 ms, max=352.093 ms, 99th percentile=1.583 ms, 99.9889% below 16.667 ms
03:28:01.926: ┣tick_sources: min=0.001 ms, median=0.012 ms, max=351.161 ms, 99th percentile=0.168 ms
03:28:01.926: ┣output_frame: min=0.117 ms, median=0.728 ms, max=13.146 ms, 99th percentile=1.381 ms
03:28:01.926: ┃ ┣gs_context(video->graphics): min=0.046 ms, median=0.114 ms, max=12.57 ms, 99th percentile=0.221 ms
03:28:01.926: ┃ ┃ ┣render_video: min=0.013 ms, median=0.045 ms, max=0.459 ms, 99th percentile=0.078 ms
03:28:01.926: ┃ ┃ ┃ ┣render_main_texture: min=0.002 ms, median=0.024 ms, max=0.113 ms, 99th percentile=0.04 ms
03:28:01.926: ┃ ┃ ┃ ┣render_output_texture: min=0.002 ms, median=0.005 ms, max=0.446 ms, 99th percentile=0.015 ms
03:28:01.926: ┃ ┃ ┃ ┣render_convert_texture: min=0.001 ms, median=0.007 ms, max=0.075 ms, 99th percentile=0.012 ms
03:28:01.926: ┃ ┃ ┃ ┗stage_output_texture: min=0 ms, median=0.007 ms, max=0.26 ms, 99th percentile=0.014 ms
03:28:01.926: ┃ ┃ ┣download_frame: min=0 ms, median=0.038 ms, max=12.474 ms, 99th percentile=0.109 ms
03:28:01.926: ┃ ┃ ┗gs_flush: min=0.013 ms, median=0.029 ms, max=0.955 ms, 99th percentile=0.093 ms
03:28:01.926: ┃ ┗output_video_data: min=0 ms, median=0.615 ms, max=2.356 ms, 99th percentile=1.188 ms
03:28:01.926: ┗render_displays: min=0 ms, median=0.08 ms, max=17.039 ms, 99th percentile=0.212 ms
03:28:01.926: video_thread(video): min=0 ms, median=0.622 ms, max=296.977 ms, 99th percentile=2.41 ms
03:28:01.926: ┗receive_video: min=0 ms, median=1.235 ms, max=296.973 ms, 99th percentile=2.514 ms, 0.562661 calls per parent call
03:28:01.926: ┗do_encode: min=0.499 ms, median=1.235 ms, max=296.973 ms, 99th percentile=2.513 ms
03:28:01.926: ┣encode(recording_h264): min=1.08 ms, median=1.344 ms, max=4.063 ms, 99th percentile=2.517 ms, 0.609264 calls per parent call
03:28:01.926: ┗encode(recording_h264): min=0.485 ms, median=0.637 ms, max=296.972 ms, 99th percentile=1.35 ms, 0.390736 calls per parent call
03:28:01.926: OBSBasic::ResetOutputs: min=0.236 ms, median=0 ms, max=0.237 ms, 99th percentile=0.237 ms
03:28:01.926: =================================================
03:28:01.926: == Profiler Time Between Calls ==================
03:28:01.926: obs_hotkey_thread(25 ms): min=24.673 ms, median=25.067 ms, max=52.641 ms, 99.8112% within ±2% of 25 ms (0% lower, 0.188787% higher)
03:28:01.926: obs_graphics_thread(16.6667 ms): min=5.932 ms, median=16.667 ms, max=352.099 ms, 99.9602% within ±2% of 16.667 ms (0.0222632% lower, 0.0174925% higher)
03:28:02.010: Number of memory leaks: 0
I never mentioned why using QuickSync has an advantage even NVENC does very well and has the same quality.
So there is no problem using NVENC ....unless you are hitting 100% GPU usage. Recording with NVENC @1440p takes like 4-9% of GPU usage and about 40-60% Video Engine usage which is very low to be fair.
But still... if you hit 100% GPU usage with NVENC, the recording suffers a drop to 10-20fps from 60fps (approximately) during that time + a bit longer. The audio track remains fine and still matches the video.
Using QuickSync obviously has no issues with hitting 100% GPU usage. Hitting 100% CPU usage is also not a problem, the recording remains perfect. Besides that you most likely not gonna hit the CPU limit in games for example.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
