Omegadev
It should be possibleAny chance of adding iTunes (not Apple Music, I mean actual iTunes) support? I still download most of my music, so it would be nice to have an option that isn't a streaming service.
Would greatly appreciate it!!It should be possible
Hello, thanks!Hi ! I don't understand how to connect my Deezer Account in the Options can you explain ? Can i use Deezer Desktop or i just can use Deezer web ? Thanks for your job is so great
I actually just tried it on brave and there it worked. Im using edge for my music so i can then control the volume etc. but its still not working on edge. I dont really know how to read this but this is 1 thing i see:That's, odd, does that happen on any soundcloud webpage? Can you check if you can see any error related to the extension in the console by pressing F12?
Alright so, in what you sent, there s no error related to MOS.I actually just tried it on brave and there it worked. Im using edge for my music so i can then control the volume etc. but its still not working on edge. I dont really know how to read this but this is 1 thing i see:
The resource https://assets.web.soundcloud.cloud/n/vendor/@[email protected] was preloaded using link preload but not used within a few seconds from the window's load event. Please make sure it has an appropriate `as` value and it is preloaded intentionally.
This picture has a few of the errors im seeing. https://imgur.com/a/PELKo3I
I made a little recording to show you what it does and hopefully it helps a bit. at first i did soundcloud and at the end i went to spotify both via edge. Hope you can figure it out :)Alright so, in what you sent, there s no error related to MOS.
My guess is that Edge does not have the same standards as other chromium based browsers, I will investigate.
Thank you for the details!
Hi, following your suggestion, the title will now be scrollign rather than getting truncated.Is there a way to have the text (for the title, say from youtube) scroll instead of being cropped off with an ellipsis?
For example, a video labeled "(Soundtrack) The Craft-How Soon Is Now" gets truncated to "(Soundtrack) The Craft-How Soo..."
Changing width of the source doesn't seem to affect its appearance. And the guide for a custom CSS doesn't seem to give any information on truncation or scrolling text.
Thank you for the video! It is indeed very helpful.I made a little recording to show you what it does and hopefully it helps a bit. at first i did soundcloud and at the end i went to spotify both via edge. Hope you can figure it out :)
Detect pause does not seem to help. it is still just popping in and out every second when music is playing. when music is paused it stays out. it does not show the song either. it's weird because it was working at first.Thank you for the video! It is indeed very helpful.
Looks like the extension is having a hard time detecting if its stopped/paused.
Time to install edge...
In the mean time, you can try disabling the "detect pause" setting in the options.
Have a nice day.
Not sure if you have done anything but it seems to be working now again... I didn't do anything lolDetect pause does not seem to help. it is still just popping in and out every second when music is playing. when music is paused it stays out. it does not show the song either. it's weird because it was working at first.
Happy new year!
Hello, thanks for the report I will take a look into it.Hello, I'd like to congratulate you on your software, but I've noticed a detail: when a music mp3 is launched on deezer, it doesn't display the title but the official one. I'd like to know if you're going to correct this or if it won't be easy (the video extract).
I know you use Google Chrome for your software, but can you suggest other browsers (FireFox, Opera etc. ...)
Thanks again for your reply.
New update bringing more customization options such as fonts and more overlay styles !
