Multiple Outputs
MasterThespian
I have the latest version of OBS and installed the OBS MultiStream plug-in, but for the life of me I can't get the panel to pull up when I select under Docks / Multiple Outputs. I click on and off the entry, but I don't get a response. It never shows up. Help! If there is a way to make it appear, please share.
I've got the same problem, Docks does not show Multiple Outlputs as the OP. I'm running OBS version 32.0.1. I'm hoping for a reply. Thanks in advance,
