Media Controls
Media Controls 0.5.0
I guess, the Source Dock plugin also fulfils this function, however it's not possible to hide the milliseconds part of the counter in that plugin (but you can on Media Controls 0.3.4)!
Hello, @Exeldro,
First of all, I would like to express deep gratitude for your continuous dedication. It's truly amazing that you continue to create impressive works.
I'd like to propose a few enhancement ideas regarding media controls.
Improvement in Media Control:
When dealing with scenes composed of multiple media files, it would be beneficial to introduce a hiding feature for unnecessary media, making it easier to find the media requiring control. Often, there's only one file that actually requires control among several media files. Therefore, introducing an option to hide the status of unnecessary media would significantly enhance the user experience.
Media Group Classification:
When using Studio Mode, considering a way to clearly distinguish between Preview and Program media would be beneficial. For instance, in cases where multiple media files are mixed in Program and Preview windows, it's challenging to locate the desired media states. If the playing media list can be divided into Program and Preview groups, it could greatly improve work efficiency.
Thank you for consistently delivering outstanding work. I'm truly grateful for your ongoing efforts and look forward to witnessing more astonishing results in the future.
Thank you.
English is not my native language, so if this text contains any expressions that may lead to unnecessary misunderstandings, please kindly disregard them.
Hello Exeldro,
my name is Mario. First of all, thank you for the incredible work you've done. I, along with some friends, stream the Handball matches of our local team. Naturally, we do this with the limited means we have, considering that Handball is a minor sport in Italy. Over time, I've managed to create instant replays of the action, which I believe are worthwhile. I have a question regarding your instant replay plugins. Is there an option for forward and backward playback? I sometimes encounter difficulties—sometimes it loads, sometimes it doesn't, and there are occasional cuts. Getting to the point, have you considered adding a feature in your media control plugins for forward-backward playback with adjustable speed? Essentially, a Video Assistant Referee (VAR) function, allowing the loading of a saved video replay to examine in detail what happened. I apologize for any mistakes in my English, and I appreciate your understanding. Mario
Wonderful plugin.
A must for OBS.
I believe almost all Exeldro plugins would have to be implemented as default ones in OBS.
Question:
Is it possible to add the "frame-by-frame" [1 frame forward - 1 frame backward] playback functionality?
It could be a huge help.
At this moment I have to capture an MPV Player window installed in another PC.
I currently have "Show All Media Sources" activated and would be happy, if the currently active (playing) Media Source could be sorted on top of the list - or is this only possible without "Show All Media Sources" activated?
Thank you for the plugin
I can't seem to get the plugin to load any of the controls, the window is blank
I tried installing it a few times, including reinstalling OBS
I'm using a mac
Any suggestions?
Exeldro, I need your help. I've downloaded your newest version 0.4.1 64-bit version and installed it. No errors during installation, it went in super smooth, and it shows up in the plugin folder. C:\Program Files\obs-studio\obs-plugins\64bit The problem is it doesn't show in View/Docks, so I am unable to use it. I'm running an older version of OBS because I'm still on Win 7 64-bit. I think I'm running the newest version that works on Win 7, which is 25.0.8 (64-bit) This newest version of Media Controls probably isn't designed to work with this OS, is there a link to old archived versions? I came up with the idea of using OBS as a giant Teleprompter, using a large screen TV. After many days of working on this I finally having it looking exactly the way I want. Large fonts, all in CAPS. The only drawback was when shooting Rock Videos, it just starts playing right away. Nearly impossible to get ready in time. Then I stumbled across I guy who promotes your contributions named "Andilippi" and viola, I thought I was saved. But after I installed it, it didn't show up. I guess I'll have to live with that. But aside from that, I'm wondering if you can code the other two features that would really make my life so much easier? One is to be able to save in Projector Screen mode, one that has the transport controls at the bottom of the screen. And maybe with the option to right click to get back to the GUI. I'd like OBS to open up in Projector Screen mode, and just hit play to start shooting the videos. That would be super SWEET!! And lastly a way to link the scrolling lyrics to the Audio backing track, so that I could time those two things together more precisely. As it now, both the scrolling and audio start as soon as you open up the program, hardly ideal. And if you pause the audio the scrolling continue. It's crazy!! Anyways, I'm open to any and all suggestions you have. It's so close now......I can almost taste it! Thank you so much for your contributions. You are a scholar among mere Men.
Just to clarify, what I'm hoping for is the ability to "Save" or what you call "Export" in Projector Screen mode, so that the Project opens up in that mode, with transport bar controls at the bottom of the page. It would be super handy as well to be able to choose the resolution of that Projector mode. (As it is now, you can only choose the resolution your computer is set at.) As an example, I've put OBS on my Surface Pro for testing now. It's default screen resolution is 2880 X 1920, so I have to reduce that resolution to 1920 X1080 to get the correct output to my TV monitor. Which means my work space (OBS) is tiny, making it harder to work in. It would be excellent to be able to work in 2880 X 1920 while still being able to use Projector Screen mode in 1920 X 1080, if you know what I mean? And as far as linking scrolling to audio media, it's crucial, if you want to time those two events precisely. I don't know if any of these things are possible to do, I'm just expressing my wish list. Things that would make my workflow so much easier. Your thoughts?
OBS GUI changed with version 28... typically plugin either work with v27 and earlier, or 28 and later... not both
Running unpatched/insecure Win7 nowadays on a networked computer is a no-no except for those with extended MS support (think large gov't contracts) and those with extensive security awareness and tools (and usually dedicated network security config to correspond.. think mfg line with old software that can't be updated) . Win10 was a bit rough at start but is fine now... I'm holding off in Win11 until last minute, and my older systems will be re-formatted with Linux.
