macOS Tahoe - Performance Issues
onsz_e
After upgrading my laptop to M4 MacBook Air it's impossible for me to use OBS. Even opening the app makes the laptop almost unusable due to the slowness and performance issues. When trying to record, the problem escalates 10 times. I don't have any error messages or anything to share cause there is no errors. I can share my OBS settings if there's a need, for now here are my specs:
I'm using macOS Tahoe 26.0
- Regular M4 processor for MacBook Air
- 24 GB Ram
- 512 GB disk space
Can please someone tell me what's happening? On my old Windows 11 laptop there is no issues whatsoever...
I have the same issue! M2 Pro Macbook Pro. Launching OBS also seems to break transparency on my menu bar (hover menu is instead blacked out), in case that may help identifying the root problem.
Having similar issues on my Mac Mini M4. It happens when I use audio or screen capture (which uses the native system capture since the captured window has its window controls changed to a blue button). As soon as I remove all audio/screen capture sources, it works well, and I can play media or use a capture card without issues.
No errors, no crashes, and the CPU usage info in the status bar never goes above 3%. I even stopped SteamDeck and disabled its plugin, and used the macOS accessibility settings to turn down transparency (thinking that the new "Liquid Glass" might be messing up).
Using the Stats dock, I see "Frames missed due to rendering lag" go up fast.
@kdy So I just have to use legacy capture methods? Or just don't use OBS whatsoever :) I guess I'll just fiddle with it for a while, and check if that's the case. Thank you!
Adding a single "macOS Screen Capture -> Display Capture" source seems to be working fine. Anything else (Window capture, App capture) tanks the framerate even when not recording / streaming.
I'm having this issue too. I open OBS, then everything slows down. OBS crashes. I reopen it, and the second time it works.
Yes, OBS overheats everything after a few minutes recording with the new Tahoe. Well, it does mean I have to split my video recordings into part 1, 2, 3 ... which is not the end of the world. Perhaps too many visual effects have been added to the mac, not impressed so far. Using mac m4 imac
Just to say that I am running Tahoe 26.2 on a M1 Mac Studio with the latest version of OBS (32.0.4). I had tested carefully on a MacBook Pro before updating my main streaming computer (the Mac Studio). After a couple weeks, and five two-hour live shows, have had no problems. All the plug-ins work, too, including Downstream Keyer, Draw, Move Transition, Stream Deck and Transition Table.
2019 Macbook Pro, i9 8 Core, UHD Graphics 630 1563 MB, 32GB DDR4.
As soon as I open obs, its get slower and slower. Not even recording. just obs open.
Would it be related to SSD write speeds? I think I have around 200gb free, my mac is mostly used for music. Rekordbox DJ. but this should be more then enough!
That's interesting. If OBS is only showing around 3% CPU but you're still getting rendering lag, I wonder if something else is happening at the system level.
Have you checked Activity Monitor while those capture sources are enabled? I recently came across GlimmerStatsBar, which shows CPU and memory usage in the menu bar. Might be useful for keeping an eye on what else is running while OBS is having trouble.
My problem is a bit different. I went to access menu bars and none of them will "take". I click on the menu, it appears and disappears before I can choose anything, including "check for updates". M4 Max on MBP with 64GB memory. On Tahoe 26.7.3
