Non-OBS Script Kill-Counter 1
Plaer1
Plaer1 submitted a new resource:
Kill-Counter - I made a script that updates a text file for counting
A little AutoHotkey + Python (3) script for displaying a kill counter (odometer style) in OBS, or possibly other applications.
What it does:
When you activate the hotkeys (Indicated in the .AHK file), it will either incriment, decriment, or reset (only the match kills) for the included data files.
How to use:
I configured OBS to load the datafile as a text element on screen, which allows you to have a dynamic text element on stream...
When I try to use this I get this error, everything is in the same directory but yet it can't find the files. Any help would be appreciated. I haven't changed anything and just went with the default hotkeys.
