Invisible text in Youtube Live Control Panel
Brave Shiba
Good evening. Lately the text in the Youtube Live Control Panel has not been visible when I launch OBS. You can see the text by highlighting it, but I was wondering if there was a method of returning it to its original white color.
The text returns if you sign in and out of your Youtube profile, but the error occurs again in the next OBS session.
I was wondering if anybody had a permanent fix or a simpler workaround.
I'm running OBS 32.2.2 64-bit on Windows.
So I found a partial fix to the issue. If you go to File->Seettings->Appearance, you can toggle the Density selection to make the text and buttons re-appear.
You have to do this every time you launch OBS though.
