I have no CQP Rate control, nor do I have the Nvenc encoder with a 3070 Graphics card please help
Sirem
I Dont have the CQP in my recording tab, I was told its because Im not using Nvenc, But I dont even have that as an encoder apparently, could someone help me please?
10:28:08.033: [Safe Mode] Unclean shutdown detected!
10:28:10.024: [Safe Mode] User elected to launch normally.
10:28:10.025: CPU Name: AMD Ryzen 5 5600X 6-Core Processor
10:28:10.025: CPU Speed: 3693MHz
10:28:10.025: Physical Cores: 6, Logical Cores: 12
10:28:10.025: Physical Memory: 65452MB Total, 55089MB Free
10:28:10.026: Windows Version: 10.0 Build 19045 (release: 22H2; revision: 3930; 64-bit)
10:28:10.026: Running as administrator: true
10:28:10.026: Windows 10/11 Gaming Features:
10:28:10.026: Game Bar: On
10:28:10.026: Game DVR: On
10:28:10.026: Game DVR Background Recording: On
10:28:10.026: Game Mode: On
10:28:10.028: Sec. Software Status:
10:28:10.029: Microsoft Defender Antivirus: enabled (AV)
10:28:10.029: Windows Firewall: disabled (FW)
10:28:10.030: Current Date/Time: 2024-01-25, 10:28:10
10:28:10.030: Browser Hardware Acceleration: true
10:28:10.030: Hide OBS windows from screen capture: false
10:28:10.030: Qt Version: 6.5.3 (runtime), 6.5.3 (compiled)
10:28:10.030: Portable mode: false
10:28:10.057: OBS 30.0.2 (64-bit, windows)
10:28:10.057: ---------------------------------
10:28:10.126: ---------------------------------
10:28:10.126: audio settings reset:
10:28:10.126: samples per sec: 48000
10:28:10.126: speakers: 2
10:28:10.126: max buffering: 960 milliseconds
10:28:10.126: buffering type: dynamically increasing
10:28:10.127: ---------------------------------
10:28:10.127: Initializing D3D11...
10:28:10.127: Available Video Adapters:
10:28:10.129: Adapter 0: NVIDIA GeForce RTX 3070
10:28:10.129: Dedicated VRAM: 8422162432 (7.8 GiB)
10:28:10.129: Shared VRAM: 34315991040 (32.0 GiB)
10:28:10.129: PCI ID: 10de:2488
10:28:10.129: HAGS Status: Disabled (Default: No, Driver status: Supported)
10:28:10.129: Driver Version: 31.0.15.4665
10:28:10.130: output 0:
10:28:10.130: name=VG27AQL1A
10:28:10.130: pos={0, 0}
10:28:10.130: size={2560, 1440}
10:28:10.130: attached=true
10:28:10.130: refresh=144
10:28:10.130: bits_per_color=8
10:28:10.130: space=RGB_FULL_G22_NONE_P709
10:28:10.130: sdr_white_nits=80
10:28:10.130: nit_range=[min=0.000000, max=603.698425, max_full_frame=603.698425]
10:28:10.130: dpi=96 (100%)
10:28:10.130: id=\\?\DISPLAY#AUS2705#5&1db803c9&0&UID45312#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
10:28:10.130: alt_id=\\.\DISPLAY2
10:28:10.130: output 1:
10:28:10.130: name=P25T
10:28:10.130: pos={2560, 360}
10:28:10.130: size={1920, 1080}
10:28:10.130: refresh=240
10:28:10.130: nit_range=[min=0.024600, max=400.000000, max_full_frame=282.855499]
10:28:10.130: id=\\?\DISPLAY#WAM2500#5&1db803c9&0&UID45318#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
10:28:10.130: alt_id=\\.\DISPLAY1
10:28:10.132: Loading up D3D11 on adapter NVIDIA GeForce RTX 3070 (0)
10:28:10.247: D3D11 loaded successfully, feature level used: b000
10:28:10.247: DXGI increase maximum frame latency success
10:28:10.247: D3D11 GPU priority setup success
10:28:10.336: ---------------------------------
10:28:10.336: video settings reset:
10:28:10.336: base resolution: 2560x1440
10:28:10.336: output resolution: 2560x1440
10:28:10.336: downscale filter: Bicubic
10:28:10.336: fps: 60/1
10:28:10.336: format: BGRA
10:28:10.336: YUV mode: None
10:28:10.336: GPU conversion not available for format: 7
10:28:10.336: NV12 texture support not available
10:28:10.337: Audio monitoring device:
10:28:10.337: name: CABLE Input (VB-Audio Virtual Cable)
10:28:10.337: id: {0.0.0.00000000}.{19be0cd2-e2e5-456c-a0ab-61632b383114}
10:28:10.337: ---------------------------------
10:28:10.339: No AJA devices found, skipping loading AJA UI plugin
10:28:10.339: Failed to initialize module 'aja-output-ui.dll'
10:28:10.340: No AJA devices found, skipping loading AJA plugin
10:28:10.340: Failed to initialize module 'aja.dll'
10:28:10.340: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
10:28:10.343: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
10:28:10.343: Failed to load 'en-US' text for module: 'decklink-captions.dll'
10:28:10.344: Failed to load 'en-US' text for module: 'decklink-output-ui.dll'
10:28:10.346: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
10:28:10.346: Failed to initialize module 'decklink.dll'
10:28:10.387: [AMF] Unable to load 'amfrt64.dll', error code 126.
10:28:10.388: [AMF] AMF Test failed due to one or more errors.
10:28:10.388: Failed to initialize module 'enc-amf.dll'
10:28:10.414: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
10:28:10.414: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
10:28:10.414: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
10:28:10.426: [obs-browser]: Version 2.22.2
10:28:10.426: [obs-browser]: CEF Version 103.0.5060.134 (runtime), 103.0.0-5060-shared-textures.2594+gc69ad37+chromium-103.0.5060.134 (compiled)
10:28:10.430: NVENC supported
10:28:10.623: [NVENC] AV1 is not supported
10:28:10.624: [noise suppress]: NVIDIA denoiser disabled, redistributable not found or could not be loaded.
10:28:10.625: Failed to get NVVideoEffects.dll version info size
10:28:10.626: [NVIDIA VIDEO FX]: FX disabled, redistributable not found or could not be loaded.
10:28:10.673: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.3.4 | RPC Version: 1)
10:28:10.673: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.5.3 | Qt version (run-time): 6.5.3
10:28:10.673: [obs-websocket] [obs_module_load] Linked ASIO Version: 102800
10:28:10.690: [obs-websocket] [obs_module_load] Module loaded.
10:28:10.695: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
10:28:10.701: ---------------------------------
In Settings > Advanced > Video switch Color format back to NV12
Set Settings > Output > Recording > Type to Standard. Don't use ffmpeg output. Even better ist just simple output mode, and while you're at it, as a baseline use Tools > Auto Configuration Wizard and optimize for recording.
