crashworks
I'm trying to configure OBS to use YouTube's recommended upload settings so that my files process faster. In particular I want to verify the more niggly configs ( GOP of 15, Chroma 4:2:0 subsampling ). I notice that some posts on this forum include a file-settings report like the one below, but after an hour of searching I can't find how to get OBS to emit it!
note: the sample below is not from my client ; I am copying an example from elsewhere on this forum
The log in my obs-studio/logs directory doesn't have anything like this level of information. Where do those reports come from and how can I get one?
Also, where can I find a list of the possible "x264 options" for the Output | Advanced window? I guess it's using libx264 , but after an hour of searching I can't find any page that documents all the options truthfully, and there is no x264 executable in my OBS directory that I can invoke with x264 --fullhelp .
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High 4:4:4 [email protected]
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=64
Codec ID : V_MPEG4/ISO/AVC
Duration : 41 s 189 ms
Bit rate mode : Variable
Maximum bit rate : 144 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 64.168 FPS
Original frame rate : 64.000 FPS
Color space : YUV
Chroma subsampling : 4:4:4
Bit depth : 8 bits
Scan type : Progressive
Default : Yes
Forced : No
Color range : Full
Matrix coefficients : BT.709
DURATION : 00:00:41.188000000
