muphase4378290
Hi everyone,
I'm trying to configure OBS to record a video with settings as close as possible to a reference file I received. Below are the specifications of the original video:
I'm Using OBS 30.0.1, on Macbook Pro 2017, 2,8Ghz I7 Quad-Core, Radeon Pro 555 2Go & Intel HD 630 1536Mo, 16Go 2133Mhz LPDDR3, OSX Ventura 13.6.9
General:
General:
- Format: MPEG-4 (Base Media)
- Codec ID: isom (isom/iso2/avc1/mp41)
- File size: 95.0 GiB
- Overall bit rate mode: constant
- Duration: 4 hours 30 minutes
- Overall bit rate: 50.0 Mb/s
- Frame rate: 25.000 FPS
- Writing application: Lavf58.29.100
- Format: AVC (Advanced Video Codec)
- Format profile: Constrained [email protected]
- CABAC: No
- Reference frames: 1 frame
- Codec ID: avc1
- Bit rate: 50.0 Mb/s
- Resolution: 1920x1080 (16:9)
- Frame rate mode: Constant
- Color space: YUV, Chroma subsampling: 4:2:0, Bit depth: 8-bit
- Scan type: Progressive
- Encoding settings: cabac=0 ref=1 deblock=0:0:0 analyse=0:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=0 weightp=0 keyint=250 keyint_min=25 scenecut=0 intra_refresh=0 rc_lookahead=0 rc=cbr mbtree=0 bitrate=50000 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=50000 vbv_bufsize=50000 nal_hrd=none filler=1 ip_ratio=1.40 aq=0
- Format: AAC LC
- Bit rate mode: Constant
- Bit rate: 320 kb/s (Track 1)
- Channels: 2 (Stereo)
- Sampling rate: 48.0 kHz
- Compression mode: Lossy
My questions:
- What is the best way to configure OBS settings to match these parameters as closely as possible?
- Are there specific x264 encoding settings I should manually enter in OBS?
- Is it possible to force constant bitrate (CBR) and disable variable bitrate (VBR) in OBS? In my attempt, log said's: "Overall bit rate mode: variable" event if i activate "CBR".
- Should I configure stream output and use same encoder in record, or create a specific record output for this setup? (i dont stream, only record)
