Frame Rate Issues on 2024 24gb iMac
beepymo
Has anyone been having issues with getting recordings at 60fps through OBS on iMac?
Even with the Output Recording settings showing 60FPS for the intended frame rate, my recordings when I view them are only going as high as 58.84 FPS.
**No issue getting 60FPS with Elgato Studio, only in OBS.
First-time user, here's my last log file I analyzed; the Log Analyzer showed no issue.
https://obsproject.com/logs/hWY67bvRo5KjI8wc
For reference, here's my setup:
2024 iMac; 24GB Ram
Elgato 4K X Capture Card
USB C 3.2 cable; 10gbps (for some reason it won't go higher than 5 gbps when looking through System Settings)
TahoeOS 26.5.1
All software updated to recent versions.
CPU Usage: 4.7%
GPU runs a bit high, roughly between 30-40% with no other apps running.
*No missed Frames due to Rendering Lag or Encoding Lag.
