Failed to start streaming help
kingdoob
I haven't used OBS to stream in a few months, but never encountered a similar issue.
The popup window says
"Starting the output failed. Please check the log for details.
Note: If you are using the NVENC or AMD encoders, make sure your video drivers are up to date."
I am using NVENC H.264, though I don't think it's an NVENC issue. For starters, my drivers are up to date. Secondly, when I try to Start Recording, I get the same error ONLY when I'm trying to use the stream encoder. If I switch the Recording encoder to instead be NVENC H.264, I don't get the error. So I don't believe this is due to not having an available NVENC session.
That's all the relevant info i can think of. Log attached.
Thanks
bumping in hopes that the 9 people who have since asked for help and received responses before me is just coincidence
attached with a simpler log of just my failure to stream
Remove all the plugins you installed.
Run the Auto-configuration Wizard and apply the settings it gives. Restart OBS and test.
Do you have any advice for removing plugins? I believed I had uninstalled the only plugin that I had installed well over a year ago
i am having the exact same problem, win 10 OBS Studio 32.0.1. What am i doing wrong?
Is all i need to stream a fast internet connection and a Twitch login? i am "darmsisi" there.
  • 2025-10-03 14-23-18.txt
  • 2025-10-03 14-38-49.txt
My problem was that I was attempting to feed live monitoring to a device that no longer existed. Resetting all of my audio monitoring settings fixed it. Good luck!
Problem solved, once i changed the server from "default" and picked one the problem went away. i'm now watching my stream on twitch...
