Downstream Keyer
Downstream Keyer 0.4.5
UPDATE: I installed OBS version 28.0.1 and Downstream Keyer worked immediately, without having to reinstall it. So, it looks like the latest version does NOT work in older versions of OBS.
I could not find the Windows installer for Downstream Keyer v0.2.3. The links I found on Github lead back to version 0.2.5. Perhaps @Exeldro could make it available somewhere?
OBS 28.0.1 seems to be working okay for me at the moment, but maybe some people still need to use version 27.
Thank you!
I have an issue where anything going through the dsk does not appear in obs virtual camera. It works properly for recordings and streams but not virtual camera.
M1 MacOS 12.5.1
28.0.1 Apple Silicon (OBS 27.2.4 Apple Silicon also installed)
Downstream Keyer 0.2.5
I want to use 28, if possible. I can't get the dock to show up in either one of these OBS versions. What do?
I have a problem, I installed obs 28 and Downstream Keyer 0.2.5 and it works in obs, but when I connect to teams, meet or zoom doesn't work in virtual cam, I don't know if it has to do with the old virtual cam plugin already does not work in version 28
Same problem with virtual cam only in obs 28. (I've downloaded 27.2.4 as portable version, copy and paste 28 version plugins folders and all works fine, just waiting for a solution). I use basicaly as virtual camera for teaching; great plugin Exeldro, as many others plugins comming from you!!! thank you a lot!!
@Exeldro
I think I've figured out what's causing the problem, but I don't know how to solve it. I keep my Home Folder on an external hard drive. I just remembered that every time I try to install a package, I always have issues with permissions because it's trying to install from an external to the internal drive. Not sure how to resolve that.
I wasn't able to install the Adobe Creative Suite with my current config, so I had to temporarily set my Home Folder back to being on the internal so I could install everything, and once everything was installed, I could switch it back to the external drive. I figured maybe that's the same thing happening here, so I set my Home Folder to the internal and rebooted. I installed Downstream Keyer, and some other plugins that weren't working. I ran OBS while still booted from the Home Folder on the internal drive, and the Downstream Keyer menu came up in OBS. (Unfortunately, the other plugins didn't work at all.)
I reset my Home Folder back to my external drive, and rebooted my computer, and when I opened OBS, Downstream Keyer was not there. So my guess is that Downstream Keyer installs by default to a place on the internal drive, but due to my configuration, it needs to be somewhere on my external. But I have no idea what to move and where.
I am having an issue where every time I open OBS an overlay from each DSK plays automatically. Am I doing something incorrectly? I am on OBS 28 with the latest version of the plugin.
Thank you very much for creating such an amazing tool. I am currently utilizing it for my daughters swim team as overlays for Event info.
I have recently reformatted my PC and am in the process of setting up OBS again.
Q: Is there any way to Backup(Export) and Restore(Import) all of the DSK Docks and events contained within each DSK Dock?
I had previously created 3 different DSK Docks (Friday, Saturday and Sunday) with each containing the Swim Events for that day. Looking for an easier way of restoring the work I have previously created vs having to recreate 72 different Events.
Thank you.
Running OBS 28.0.3 and the DSK plugin 0.2.5. As others have noted, the overlays show fine in the program window when the keyer is activated, but the overlays do not appear in the output from the virtual camera. As of now (October 10), what is the best fix or workaround to solve this problem?
Windows 10, Dell, i5
I believe I have found my own solution. As others have noted, there is an alternative virtual camera plug-in for OBS called Droidcam.
I have just installed it, and it solves the problem with the downstream keyer.
You have to download and install both the Droidcam exe file and the drivers file separately to the OBS program files folder.
Once Droidcam is installed, you do not need to push the "virtual camera" button in OBS. You will find Droidcam appearing as an available device under the video settings menu in ZOOM. You select that instead of OBS virtual camera.
It appears that Droidcam also supplies a virtual audio cable output from OBS that can be selected in ZOOM the same way the virtual webcam can be selected.
Ejecutando OBS 28.0.3 y el complemento DSK 0.2.5. Como han señalado otros, las superposiciones se muestran bien en la ventana del programa cuando se activa el manipulador, pero las superposiciones no aparecen en la salida de la cámara virtual. A partir de ahora (10 de octubre), ¿cuál es la mejor solución para resolver este problema?
I have the same problem with the version of obs 28.0.3 I'm going to try the droidcamara option but where do you get it?
Windows 10, Dell, i5i
hi! sorry for my English. I've a portable 27.2.4 version installed -with all the plugins I need- for the situations I need to use virtual cam. I have always had an installed version (testing) and a portable version (production) Everything works fine in 27.2.4 for my needs.
