GrumpyDog
Member
JEJ submitted a new resource:
Simple Stopwatch - Text-layer-based stopwatch in OBS Scene
Add a Text (GDI+) Source that will display the Stopwatch Time Stamp.
The Stopwatch will show Hours:Minutes:Seconds:MIliseconds (00:00:00,00)
Ability to change Text Color by specific Time Value
It should be noted that the Miliseconds render is limited (based on) the Video Frame Rate. For best results a Frame Rate of 60 FPS is recommended.
* Also See File>Settings>Video>FPS Values
[ATTACH type="full"...
Version 0.2
Add ability to define media to play at 'Caution' and 'Warning' state.
Media file will be reset after media ended, or if Media has looping enabled, user can define a time in Seconds to disable media
JEJ updated Simple Stopwatch with a new update entry:
Version 2.0
All things up and all things down in time.
Modes:
1) Stopwatch
2) Countdown
Property Configuration:
1) Basic - Hides all advanced settings
2) Advanced - Show all available configurations
Note:
Properties defined in 'Advanced' settings will remain active even if the config is set to 'Basic'. The purpose here is to remove clutter settings.
Some options are hidden, and will only become available if they are relevant to the parent property.
The useris able to...
Would be very neat to have this be dockable inside of OBS, this way a person could adjust a timer much easier.. by adding in 2 minutes, or subtracting 10..
HI,
I am a bit new to OBS and having trouble installing this. Where does the file go?
Really looking for a Stopwatch that will reset to Zero on each transition.
On a Mac, don't know if it makes a difference.
Thanks
Hi Rayco
Typically Scripts are stored here:
C:\Program Files\obs-studio\data\obs-plugins\frontend-tools\scripts
But in reality you can place the file in any folder. To install it in OBS, you simply open OBS and on the top menu go to Tools and Scripts, then click the '+' plus icon on the Script Dialog, find the location wher you installed the script file and select. That should be it.
  1. Open up the Scripts dialog (Tools -> Scripts)
  2. Click the Plus '+' to add a new Script, select 'yourfile.lua'
Hope this helps!
This would be cool, but currently is a limitation by OBS or available plugins.
