Question / Help CAN´T STREAM WITH OBS , NVIDIA SHADOWPLAY RUNS 1080p 60 PERFECTLY WTF?!
drjerbasio
I have tried everything and I WANT to use OBS, it has much more features than nvidia shadowplay but I can´t get it to work,NOT EVEN with this low af settings please HELPP
I dont believe it´s a PC problem:
• GPU: GeForce GTX 970
• CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
• memory: 32 GB RAM (31.95 GB RAM free)
• Resolución actual: 1920 x 1080, 144Hz
• Sistema operativo: Microsoft Windows 10 Home
Also I have +10000Kbps in Madrid,Spain server
Here is my config:
I dont know if its a Fortnite problem or a PC IDK
Strange fact, when i toggle off the game , it runs smoothly on stream WTF?
Please help I really want to use tools that make the stream much more entertaining and engaging.
ALSO MY FORTNITE SETTINGS ARE NOT REALLY DEMANDING
HERE ARE THE COMPARISONS BETWEEN A STREAM WITH THE SAME SETTINGS BETWEEN OBS AND SHADOWPLAY + THE TASK MANAGER AND THE CPU AND GPU USAGE WHILE STREAMING: (I just realised this while posting the links, the matter of fact is OBS only captured around 4 frames LOL near the end is the task manager so you can see the GPU usage is around 100% and in Nvidia shadowplay is 50% ang GPU is 40%)
SAME SETTINGS: 6000 bitrate, 1920X1080 60fps
OBS:https://www.twitch.tv/videos/263492728
NVIDIA:https://www.twitch.tv/videos/263493787
Provide an OBS log of a recording or streaming session.
17:07:07.259: CPU Name: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
17:07:07.259: CPU Speed: 4000MHz
17:07:07.259: Physical Cores: 4, Logical Cores: 8
17:07:07.259: Physical Memory: 32716MB Total, 23929MB Free
17:07:07.259: Windows Version: 10.0 Build 17134 (revision: 48; 64-bit)
17:07:07.259: Running as administrator: false
17:07:07.259: Aero is Enabled (Aero is always on for windows 8 and above)
17:07:07.259: Windows 10 Gaming Features:
17:07:07.259: Game Bar: On
17:07:07.259: Game DVR: On
17:07:07.259: Game DVR Background Recording: Off
17:07:07.261: Sec. Software Status:
17:07:07.263: Antivirus de Windows Defender: enabled (AV)
17:07:07.263: Firewall de Windows: enabled (FW)
17:07:07.264: Antivirus de Windows Defender: enabled (ASW)
17:07:07.265: Portable mode: false
17:07:07.429: OBS 21.1.2 (64bit, windows)
17:07:07.429: ---------------------------------
17:07:07.430: ---------------------------------
17:07:07.430: audio settings reset:
17:07:07.430: samples per sec: 44100
17:07:07.430: speakers: 2
17:07:07.538: ---------------------------------
17:07:07.538: Initializing D3D11...
17:07:07.538: Available Video Adapters:
17:07:07.543: Adapter 1: NVIDIA GeForce GTX 970
17:07:07.543: Dedicated VRAM: 4255580160
17:07:07.543: Shared VRAM: 4268062720
17:07:07.543: output 1: pos={0, 0}, size={1920, 1080}, attached=true
17:07:07.546: Loading up D3D11 on adapter NVIDIA GeForce GTX 970 (0)
17:07:07.642: D3D11 loaded successfully, feature level used: 45056
17:07:09.078: ---------------------------------
17:07:09.078: video settings reset:
17:07:09.078: base resolution: 1920x1080
17:07:09.078: output resolution: 1280x720
17:07:09.078: downscale filter: Bilinear
17:07:09.078: fps: 30/1
17:07:09.078: format: NV12
17:07:09.078: YUV mode: 601/Partial
17:07:09.082: Audio monitoring device:
17:07:09.082: name: Por defecto
17:07:09.082: id: default
17:07:09.082: ---------------------------------
17:07:09.299: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
17:07:09.386: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
17:07:09.737: [AMF] AMF Test failed due to one or more errors.
17:07:09.737: Failed to initialize module 'enc-amf.dll'
17:07:10.909: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
17:07:10.995: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': (null) (127)
17:07:10.995: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
17:07:11.171: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
17:07:11.422: [browser_source: 'Version: 1.31.0']
17:07:11.955: NVENC supported
17:07:13.334: Couldn't find VLC installation, VLC video source disabled
17:07:13.644: No blackmagic support
17:07:14.153: ---------------------------------
17:07:14.153: Loaded Modules:
17:07:14.153: win-wasapi.dll
17:07:14.153: win-mf.dll
17:07:14.153: win-ivcam.dll
17:07:14.153: win-dshow.dll
17:07:14.153: win-decklink.dll
17:07:14.153: win-capture.dll
17:07:14.153: vlc-video.dll
17:07:14.153: text-freetype2.dll
17:07:14.153: rtmp-services.dll
17:07:14.153: obs-x264.dll
17:07:14.153: obs-vst.dll
17:07:14.153: obs-transitions.dll
17:07:14.153: obs-text.dll
17:07:14.153: obs-qsv11.dll
17:07:14.153: obs-outputs.dll
17:07:14.153: obs-filters.dll
17:07:14.153: obs-ffmpeg.dll
17:07:14.153: obs-browser.dll
17:07:14.153: image-source.dll
17:07:14.153: frontend-tools.dll
17:07:14.153: enc-amf.dll
17:07:14.153: coreaudio-encoder.dll
17:07:14.154: ==== Startup complete ===============================================
17:07:14.193: All scene data cleared
17:07:14.193: ------------------------------------------------
17:07:14.283: WASAPI: Device 'Altavoces (USB PnP Audio Device)' initialized
17:07:14.329: WASAPI: Device 'Micrófono (Yeti Stereo Microphone)' initialized
17:07:14.349: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
17:07:14.388: adding 46 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
17:07:14.398: ---------------------------------
17:07:14.398: [DShow Device: 'Dispositivo de captura de video'] settings updated:
17:07:14.398: video device: Logitech HD Pro Webcam C920
17:07:14.398: video path: \\?\usb#vid_046d&pid_082d&mi_00#6&25c6bc4a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
17:07:14.398: resolution: 640x480
17:07:14.398: fps: 30.00 (interval: 333333)
17:07:14.398: format: I420
17:07:15.746: Switched to scene 'Escena'
17:07:15.746: ------------------------------------------------
17:07:15.746: Loaded scenes:
17:07:15.746: - scene 'Escena':
17:07:15.746: - source: 'Capturar Juego' (game_capture)
17:07:15.746: - source: 'Dispositivo de captura de video' (dshow_input)
17:07:15.751: [game-capture: 'Capturar Juego'] attempting to hook fullscreen process: FortniteClient-Win64-Shipping.exe
17:07:15.783: [game-capture: 'Capturar Juego'] shared texture capture successful
17:10:58.083: ---------------------------------
17:10:58.083: video settings reset:
17:10:58.083: base resolution: 1920x1080
17:10:58.083: output resolution: 1920x1080
17:10:58.083: downscale filter: Bicubic
17:10:58.083: fps: 60/1
17:10:58.083: format: NV12
17:10:58.083: YUV mode: 601/Partial
17:10:58.110: Settings changed (outputs, video)
17:10:58.110: ------------------------------------------------
17:11:00.574: ---------------------------------
17:11:00.710: [NVENC encoder: 'streaming_h264'] settings:
17:11:00.710: rate_control: CBR
17:11:00.710: bitrate: 6000
17:11:00.710: cqp: 0
17:11:00.710: keyint: 120
17:11:00.710: preset: default
17:11:00.710: profile: main
17:11:00.710: level: auto
17:11:00.710: width: 1920
17:11:00.710: height: 1080
17:11:00.710: 2-pass: true
17:11:00.710: b-frames: 2
17:11:00.710: GPU: 0
17:11:00.710:
17:11:01.150: ---------------------------------
17:11:01.150: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
17:11:01.150:
17:11:01.299: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-mad.twitch.tv/app...
17:11:01.344: [rtmp stream: 'adv_stream'] Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
17:11:02.804: [rtmp stream: 'adv_stream'] Connection to rtmp://live-mad.twitch.tv/app successful
17:11:02.857: ==== Streaming Start ===============================================
17:14:01.012: adding 139 milliseconds of audio buffering, total audio buffering is now 208 milliseconds
17:14:21.589: [rtmp stream: 'adv_stream'] User stopped the stream
17:14:21.589: Output 'adv_stream': stopping
17:14:21.589: Output 'adv_stream': Total frames output: 11832
17:14:21.589: Output 'adv_stream': Total drawn frames: 11283 (12020 attempted)
17:14:21.589: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 737 (6.1%)
17:14:21.590: Video stopped, number of skipped frames due to encoding lag: 44/11925 (0.4%)
17:14:21.592: ==== Streaming Stop ================================================
17:14:21.934: warning: 2 frames left in the queue on closing
17:14:33.021: ---------------------------------
17:14:33.021: video settings reset:
17:14:33.021: base resolution: 1920x1080
17:14:33.021: output resolution: 1536x864
17:14:33.021: downscale filter: Lanczos
17:14:33.021: fps: 60/1
17:14:33.021: format: NV12
17:14:33.021: YUV mode: 601/Partial
17:14:33.039: Settings changed (video)
17:14:33.039: ------------------------------------------------
17:14:52.436: ---------------------------------
17:14:52.436: [NVENC encoder: 'streaming_h264'] settings:
17:14:52.436: rate_control: CBR
17:14:52.436: bitrate: 6000
17:14:52.436: cqp: 0
17:14:52.436: keyint: 120
17:14:52.436: preset: default
17:14:52.436: profile: main
17:14:52.436: level: auto
17:14:52.436: width: 1536
17:14:52.436: height: 864
17:14:52.436: 2-pass: true
17:14:52.436: b-frames: 2
17:14:52.436: GPU: 0
17:14:52.436:
17:14:52.606: ---------------------------------
17:14:52.606: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
17:14:52.606:
17:14:52.608: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-mad.twitch.tv/app...
17:14:52.636: [rtmp stream: 'adv_stream'] Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
17:14:54.188: [rtmp stream: 'adv_stream'] Connection to rtmp://live-mad.twitch.tv/app successful
17:14:54.192: ==== Streaming Start ===============================================
17:15:32.153: User added source 'Imagen' (image_source) to scene 'Escena'
17:15:45.490: warning: Warning: data is not aligned! This can lead to a speed loss
17:19:45.548: ---------------------------------
17:19:45.548: [DShow Device: 'Dispositivo de captura de video'] settings updated:
17:19:45.548: video device: Logitech HD Pro Webcam C920
17:19:45.548: video path: \\?\usb#vid_046d&pid_082d&mi_00#6&25c6bc4a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
17:19:45.548: resolution: 640x480
17:19:45.548: fps: 30.00 (interval: 333333)
17:19:45.548: format: I420
17:24:13.560: [rtmp stream: 'adv_stream'] User stopped the stream
17:24:13.560: Output 'adv_stream': stopping
17:24:13.560: Output 'adv_stream': Total frames output: 33536
17:24:13.560: Output 'adv_stream': Total drawn frames: 31101 (33657 attempted)
17:24:13.560: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 2556 (7.6%)
17:24:13.564: ==== Streaming Stop ================================================
17:24:13.637: warning: 2 frames left in the queue on closing
Disable gameDVR.
Enable VSYNC or limit your ingame frame rate to 60.
Thanks for your attention Volfield,
Where can i disable Game DVR? Its not an OBS setting right?
Also VSYNC is a game setting? thanks in advance
For gameDVR:
Start menu--->Cogwheel on the left OR Windows key + i, select "Gaming" in the newly opened window then disable every single option in every single category.
VSYNC or Vertical synchronization is a game option.
You could try "High Quality" preset under NVENC settings instead of "Default" and 720p@60FPS, which IMO is the sweetspot for smoothness and resolution, since the majority of people I've talked to keep chat open or watch over mobile.
One more question , i have +10K bitrate at Madrid server, whats the best bitrate to stream?
Also does the bitrate means +more bitrate better quality?
Or maybe lowering it makes for a more smooth stream?
Higher bitrate = higher quality, though there are diminishing returns past a certain number.
At this time, Twitch allows a max of 6000Kbps so 720p@60FPS would need 3500-5500Kbps, depending on the game.
If you're an affiliate and have quality options on your stream, always go for 5500Kbps. If you're not, be aware that higher bitrates might result in fewer viewers being able to watch due to slower internet speeds on their end and buffering as a result.
Not sure if this is a dead forum or my issue is simular since the links dont work anymore but i have this slight stuttering issue with my video recordings and streams, Nvidia Highlights are always smooth and crystal clear, Ive tried the everything mentioned thus far and here are my settings and appearance:https://streamable.com/bmlyx8
You need to contact Streamlabs for support with their product. This thread is also two years old.
