Background Removal / Virtual Green-screen & Low-Light Enhance
Background Removal / Virtual Green-screen & Low-Light Enhance v1.4.1
You deleted the fully completed bug report with the summarized words: "We are not your slavery". I submitted the bug-report because I think that it has something to do with OBS itself. Because no matter which Background Removing Tool I use the black outline appears everywhere. But as you deleted the report I'm no longer interested in fixing. I made a hardware-based workaround by using a HDMI-splitter and inputing two different signals from one cam. With touchportal I split the logic in half plugin-used and half-hardware used depending on the scene I'm using. It could be easier but every background-removal choice that runs via hardware gives a slightly lag that is visible if you overlay the bg-removed source with the original.
Thank you for detailed feedback! Unfortunately, our product does not fit your needs. I'm happy to hear from you that you find a suitable product for you. Enjoy your streaming!
This does NOT work!
For starters, there's NO installer in the download page, so no idea where that is "added".
The 'How To' in this download, says to put the folder in 'Plugins' (Quote: Copy the `obs-backgroundremoval` folder to your OBS Studio plugins directory), doesn't work, OBS can't find it in its Filters.
A person in OBS Discord Serer said I should ONLY put .dll file in the 'Plugins', and the rest in 'Data', which makes me FIND it in its Filters, but it doesn't work (no changes) and just crash my OBS (V32, on Win11 x64) when deleting the filter... Can you fix this??
AND make a DETAILED VIDEO tutorial how you install this, because clearly, I'm too stupid.
Hello @royshilkrot,
Your plugin is amazing, congratulations!
However, the latest package isn't installing correctly on Linux. The destination directory points to "usr/local/..." instead of "usr/...", and there are unresolved dependencies (libonnxruntime1.23, libopencv-core410, libopencv-imgproc410).
Thanks in advance!
Hello @royshilkrot,
Thanks in advance!
Thanks for reporting! I will fix this in 1.4.2!
The latest release targeting the unreleased and targeted for 2027 debian forky is not compatible wit the Ubuntu 26.04 LTS that OBS officially supports - https://obsproject.com/kb/linux-installation.
Will there be Linux release for the official OBS supported versions of Ubuntu release added as well?
We work hard to improve Linux support, and Ubuntu support will be back in 1.4.2 or 1.4.3. Note that deb of 1.4.1 is broken and not working at all even on Debian Forky.
Doesn't work for me. I can throw the dll in the plugins folder and it shows up, but the plugin itself does not working when adjusting sliders etc.
Also, there is no such folder as 'ProgramData' only 'Program Files' on Windows...
Of course it's there—it's just hidden in the folder at C:\ProgramData\. It's easy—you can see everything in Total Commander!
This is a cool little plugin - is there anywhere with a guide that explains all the options and their performance impacts? My stream tanked down to 4.9 FPS with it active and I'm not sure what I did to make that happen on an RTX 5070 and a Ryzen 9900X
