Automate 24/7 Stream for a scheduled Playlist
Hi .... this is interesting
I did some experiments and managed to create an integrated system using RadioDJ as an automation system and use OBS to visualize all the items that played. This becomes possible since RadioDJ can play MP4 files. To do this, I write some script to give orders to the 'OBS command line' a local files path reference from RadioDJ to the 'Media Source' in OBS.
I've seen radiodj before and it seems like a powerful app and importantly, supported. I guess my question is about the script you write. Is this a one time script or do you have to write/update this script each time you wish to use it? Also, is linux use, part of the "this is interesting" comment. Sometimes when many people are talking, it's hard to tell whos comment you are refering to.
@everyone Well, everything is going good with the casttor project. We have a new 'real' user located in Maine. This is a 6 town cable channel setup with 9 active channels using casttor, 6 government town meetings etc, 3 community access channels. This is in addition to the channel running in the netherlands for the past year. The saco river project (maine,usa) replaced commercial equipment costing 100k and a maintenance contract costing 20k annually with 9 computers, each running a copy of casttor and obs for their 9 channel system. I was told that the project cost was 28k total. I was also told that the programming time went down from 8 hours per week to 30 minutes for the 6 government channels. I love hearing that.
Complete automation playlists would be the BEST professional add-on to OBS. I run a TV channel, and I need to play commercials from time to time, like a playlist of commercials, choosed randomly inside a major playlist of the program videos. A scheduled playlist that would fit time exactly would also be a dream. How to do that in VLC ? We could automate VLC and send it to OBS.
did you ever work it out?
ffplayout works really well. 24 playlist, live ingest, ads, DSK.
I'm curious. How long does it take to set up a weeks worth of (NEW) programing. I imagine you can cut and paste previous playlists, but how much work does it take to set up a new playlist. Do you plan to share with others? I found that with my program, it's taking more timeto share and train then working on the code.
Check for yourself:
ffplayout:
frontend (playlist editor):
also you can use REST API (https://ffplayout.github.io/ffplayout-api/) and build your own editor. Playlists are simple JSON files.
And some features:
  • have all values in a separate config file
  • dynamic playlist
  • replace missing playlist or clip with a dummy clip
  • playing clips in watched folder mode
  • send emails with error message
  • overlay a logo
  • overlay text, controllable through messenger or ffplayout-frontend (needs ffmpeg with libzmq and enabled JSON RPC server)
  • EBU R128 loudness normalization (single pass)
  • loop playlist infinitely
  • remote source
  • trim and fade the last clip, to get full 24 hours
  • when playlist is not 24 hours long, loop filler clip until time is full
  • set custom day start, so you can have playlist for example: from 6am to 6am, instate of 0am to 12pm
  • normal system requirements and no special tools
  • no GPU power is needed
  • stream to server or play on desktop
  • logging to files, or colored output to console
  • add filters to input, if is necessary to match output stream:
    • yadif (deinterlacing)
    • pad (letterbox or pillarbox to fit aspect)
    • fps (change fps)
    • scale (fit target resolution)
    • aevalsrc (if video have no audio)
    • apad (add silence if audio duration is to short)
    • tpad (add black frames if video duration is to short)
  • output:
    • stream
    • desktop
    • HLS
    • null (for debugging)
  • JSON RPC server, for getting infos about current playing and controlling
  • live ingest
  • Multi Channel
from your handle, were you born in 1975?? lol. From working on my own app, I can tell you spent a lot of hours in design and implementation. I am facing the gethub doc trail problem and am currently at a loss. I'm starting from beginning and facing the gethub learning curve. "casttor" is currently in beta test. I have 3 main testers now. One is a news station in the netherlands (running for a year and a half), 2, a 6 township gov channel in Maine and a reku channel that we are going to livestream. Its a fully based GUI, but alas windows only. Casttor is "show" based which means that a show contains all the videos,promos, add, bumpers, overlays etc. I noticed a line in you doc about stability and I totally agree. For a program that needs to run 24/7, it can'tCRASH. Thank you for sharing. We can talk more if you like. I'd like to hear more about some of the technical problems and how you solved them.
Yes, I was born in 1975. What's your deal?
ffplayout isn't mine. I just shared the link with with you 'cause I see you struggle with playlist editor.
Didn't mean to ruffle your feathers. I'm older than you anyway. Just being social. Want to thank you for your response , which is about helping other people in the community. I actually thought you were the author. I just thought it would be interesting to talk "tech talk" to the author. Sorry again
Here is a demo of how casttor can create a month of 24/7 programming, in basically about 20 minutes. I tried to be a little funny with a voice over lead-in intro. I think I need to practice. We are probable in the last round of beta testing. Please comment. It's a 4k video so you will need to watch it on a 4k screen.
Nice adition to unattended players/playlist editors.
One time payment, $49 for NDI version. The cheapest on the market (I think) and with 14-day trial.
Price includes:
SD/HD/2K/4K Playout
CG Editor
Playlist Creation
Schedule
Log Report
LIVE Input from BlackMagic Designs Decklink, AJA, Magewell, Bluefish 444, Stream labs, Osprey and Deltacast cards
Dual Playout
Supports SRT, WebRTC
Stream INPUT RTMP, UDP, HLS
NDI Input
NDI Output
Info, screenshots, shop here: http://www.instaplayout.com/
I have nothing to do with the program or the creators - I just came across a new tool and thought there was no point in reinventing the wheel.
Thank you for the info. It's always a treat to see how other people do things. Casttor uses obs as the front end, so basically can do whatever obs can do.
Actually a different wheel. Casttor creates tv shows with inserts, overlays using templates.,etc One of the features is that there is an overlay editor in addition to a timeline editor. It can do playout as a side benefit, but was designed to look like network tv. Think of hogans heros scheduled from 9 to 9:30 pm. Think of scheduling a months worth of 24/7 in 15 minutes. Casttor is an automated compositor that you control.
Anyway thanks for the info. We can talk further if you like.
Price includes:
SD/HD/2K/4K Playout
CG Editor
Playlist Creation
Schedule
Log Report
Dual Playout
NDI Input
NDI Output
too expensive for me ($ 250 BRL)
It all depends on what you are trying to do and why. If you have a real project in mind that you feel a passion for and want to just "get" on with it, then bite the bullet, try their free trail and is if it fits. instaplayout looks reasonable but tedious if you wish to do 24/7. If you want to "play" or use it for "education", maybe the $49 version would work. i saw you were asking for a master control software in you resource request. Share with us what you may want to do, maybe someone can help.
Hi everyone, I've been perusing this thread and it sounds like I'm in the right place... Forgive me for being that guy but in the interest of efficiency not just for myself but others who will stumble in here looking for a solution, is anyone able to distill where things stand with this problem? It's not easy to find a definitive solution online and at 25 pages over 5 years this thread's become a bit unwieldy. For my case specifically I'm on Mac, looking for an approach to achieve a simple automated playback schedule that looks something like this:
The more idiot-user friendly and inexpensive the solution the better! Any guidance would be appreciated!
easy for casttor. here is a sample video when scheduling https://www.youtube.com/watch?v=XDrO9oioNIY
It's in beta test, so no cost if you want to be a beta tester.
OH,OH, SORRY, This is a windows solution only, not mac. Don't know if this would work on mac bootcamp. But this is exactly what you want. no plans to port to maC or Linux.
It would take a bit of setup, but if you had a scene for each, and macro for each in the Advanced Scene Switcher plugin:
Then you could do this:
(doesn't do anything on its own, but provides something to reuse a lot)
First reuse. Also keep track of where we are in the overall sequence (the Current State variable), and run a random macro from the list of Short Videos. You'll see one of those at the end.
The Current State has gotten all the way down to zero, so do the first other thing now, which is the first ID bumper, and continue to count down. It'll be negative from here on, which makes it a little bit easier to just read off where it is just by looking at that variable.
If you understood the previous two, then you probably have this one too. :-)
Last one in the sequence, so reset the Current State instead of decrementing. The value here is the only thing that sets the number of short videos, so tweak it accordingly.
This is the one you need to copy, and have a separate one for every video. Also have a separate scene for every video, with only that video in it. Each of these macros has no conditions, and switches to its own scene.
The Transition Duration works with the Time Remaining Shorter all the way up top, to make a nice transition while both videos are playing. Adjust the times as needed, but keep them all equal, or the Time Remaining slightly longer.
What ends up happening, in terms of the Current State:
6: Short Video, decrement Current State
5: Short Video, decrement Current State
4: Short Video, decrement Current State
3: Short Video, decrement Current State
2: Short Video, decrement Current State
1: Short Video, decrement Current State
0: Station ID, decrement Current State
-1: Long Video, decrement Current State
-2: Station ID, set Current State to 6
For efficiency, you asked a question and 2 people answered with possible solutions. If you were serious about an actual project, what did you decide to do?
Here is a a sample printout of a casttor scheduled program/template REPORT that easily does want you want. This one is setup for 30 minutes so has only 2-3 short videos in the fill block. It also includes an end graphic and various overlays Casttors scheduler can then schedule and repeat this all day long or mix it in with other programs, think barney miller and hogan's hero's. It can pick out different files in either random or shuffle mode. The second report shows what happens when the template is run twice, i.e. the first one would be a 1pm, lets say and the second a 1:30. You will see, same source folders, but completely different contents, a new show every time. I don't know if you were just be helpful in suggesting what we need or have a real project in mind. So lets us know.
Hi Bill,
I am a technician for O'Maine Studios in Portland, Maine. We are a video production facility in the process of starting a streaming service called StreamState (URL: streamstate.tv), which consists of an automated playout channel and a pay per view library, both containing programming featuring aspects of our state - tourism, food, live events, locally produced productions, etc.
What brought me to this forum topic (CASTTOR) was our search for a playout solution that can handle live webcam RTMP feeds - scenic vistas from around the state, which is one of the unique attributes of our channel.
We started with trying out some of the expensive playout options, none of which seemed to handle a sequence of looping live webcam inputs without shortly crashing. The clear winner for pulling this off turned out to be OBS, using the sequencer in Advanced Scene Switcher. It will run 12 consecutive inputs (and hopefully more) in a loop for well over 24 hours (with dissolves!) without crashing. But OBS is a switcher, not an easy to program playout solution. So I ended up on this OBS forum thread, reading with great interest your development of CASTTOR.
I really like how CASTTOR can handle blocks of prerecorded clips and programs, which can easily be moved to different time slots - a rmajor time saver it seems. This could also be great if it can handle a sequence of live webcams as well. I'm hoping that since our live webcam sequences work so well in OBS, they would carry this capability over to CASTTOR.
It was fun to see that you have a beta tester for Saco Valley. I worked at Maine Video Systems (for 40 years - now closed), and they were one of our customers.
A few weeks ago we produced a live event described in this article:
https://www.penbaypilot.com/article...-movies-tv-live-video-everything-maine/254843
Since this event was at a remote area without internet, we used a StarLink antenna, which worked great, getting our signal to our CDN. We had viewers from as far away as Oregon and Hawaii.
We are interested in the free trial, and becoming a beta tester and user.
My contact info:
Eric Jurgenson
O'Maine Studios
https://https://streamstate.tv
[email protected]
(207) 232-8043
Hi Bill,
My contact info:
Eric Jurgenson
O'Maine Studios
[email protected]
(207) 232-8043
If you get a 408 call, it's me and not a spam risk.
