danielshofar
Hi everyone,
I’m experiencing an audio delay issue during streaming and local recording with OBS. Here’s my setup:
During both live streams and local recording, the audio gets delayed relative to the video. The delay only occurs in OBS outputs. The source camera’s recording is perfectly in sync.
my audio buffering spikes to 960ms
Are my settings actually correct?
logs are here :
Thanks in advance!
- Camera: Sony ZV-E10 II
- Capture card: Elgato Camlink 4K
- Microphone: DJI Mini Mic 2 (connected to the camera)
- OBS: Streaming simultaneously to YouTube and my personal website via RTMP (RTMP via multiple output plugin
- Local recording: OBS records locally to my PC
- Additional: Camera itself records a copy independently (this copy has no sync issues)
- My upload speed is 80 Mbps.
My System Specs :
- Processor: Intel Core i7-13620H (2.40 GHz, 13th Gen)
- RAM: 16.0 GB (15.6 GB usable)
- GPU: NVIDIA GeForce RTX 4070 Laptop GPU
- VRAM: 7948 MB
OBS Video Settings:
- Base Resolution: 1920x1080 (16:9)
- Output Resolution: 1920x1080 (16:9)
- FPS: 30
OBS Audio Settings:
- Sample Rate: 48 kHz
- Channels: Stereo
- Audio Bitrate: 160 kbps (all tracks)
- Output Mode: Advanced
- Video Encoder: NVIDIA NVENC H.264
- Audio Encoder: FFmpeg AAC
- Rate Control: Constant Bitrate
- Bitrate: 4500 Kbps
- Keyframe Interval: 2 seconds
- Preset: P5: Slow (Good Quality)
- Tuning: High Quality
- Multipass Mode: Two Passes (Quarter Resolution)
- Profile: high
- Look-ahead: Disabled
- Adaptive Quantization: Disabled
- Protocol: RTMP
- using "Reuse the streaming encoder as OBS" for both Video Settings and Audio Settings.
Advanced Settings:
- Process Priority: Above Normal
- Stream Delay: Disabled
- Auto Reconnect: Enabled (2s delay, 25 max retries)
- Network Optimizations: Disabled
- TCP Pacing: Disabled
- Browser Hardware Acceleration: Enabled
Recording Settings:
- Recording Path: D:\Videos
- Format: MPEG-4 (.mp4)
- Video Encoder: Use stream encoder
- Audio Track: 1
- Auto File Splitting: Enabled (by time)
logs are here :
Thanks in advance!
