Bug Report ARB_GLX_create_context not supported! with Mesa 13
Panakotta00
Hello, i got an error when i start obs with mesa for OpenGL 3.3 in Debian
My glxinfo for OpenGL:
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.8, 256 bits)
OpenGL version string: 3.3 Mesa 13.0.6
OpenGL shading language version string: 3.30
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
My error:
info: Initializing OpenGL...
error: ARB_GLX_create_context not supported!
error: Failed to create context!
error: device_create (GL) failed
error: Failed to initialize video. Your GPU may not be supported, or your graphics drivers may need to be updated.
The libegl1-mesaversion in dpkg:
Package: libegl1-mesa
Status: install ok installed
Priority: optional
Section: libs
Installed-Size: 257
Maintainer: Debian X Strike Force <[email protected]>
Architecture: amd64
Multi-Arch: same
Source: mesa
Version: 13.0.6-1~bpo8+1
Replaces: libegl1-x11
Provides: libegl1-x11
Depends: libc6 (>= 2.17), libdrm2 (>= 2.4.66), libexpat1 (>= 2.0.1), libgbm1 (= 13.0.6-1~bpo8+1), libwayland-client0 (>= 1.3.92), libwayland-server0 (>= 1.2.0), libx11-6, libx11-xcb1, libxcb-dri2-0 (>= 1.8), libxcb-dri3-0, libxcb-present0, libxcb-render0, libxcb-shape0, libxcb-sync1, libxcb-xfixes0, libxcb1 (>= 1.9.2), libxshmfence1
Pre-Depends: multiarch-support
Conflicts: libegl1-x11
Description: free implementation of the EGL API -- runtime This package contains the EGL native platform graphics interface library. EGL provides a platform-agnostic mechanism for creating rendering surfaces for use with other graphics libraries, such as OpenGL|ES. . This package contains modules to interface with the existing system GLX or DRI2 drivers to provide OpenGL via EGL.
Homepage: https://mesa3d.org/
And the obs-studio version in dpkg:
Package: obs-studio
Priority: extra
Section: checkinstall
Installed-Size: 19244
Architecture: amd64
Version: 20170513-git-1
Provides: obs-studio
Description: Package created with checkinstall 1.6.2
So... it was horrible to get mesa 13... and now that? Please can anybody help me!
