Hello i have a problem and is that when i put some images as logos they just do not work
The 1st image just works fine and the 2nd the image doesn´t appear and is same kind of PNG file, just everything fine, do you know why this happen, is very bad because is so random...
Thanks in advance.
Hi NoeAL,
first your idea with the control panel is very good and helpful.
But there is one bugs I have to notice:
  • The Export function does´nt includes the data from every memory slot. Only the last one used is
    included. (Where are these memory slots stored?)
The practical usage for us is that every time we stream our service the names shown in the lower thirds must be typed in
in the control panel. I would be nice to have a simple file which is read at startup or with a hot-key action. So we can prepare
a file with the text lines and some additional color information.
I have just installed OBS 28.0.3 on my new laptop Lenovo ThinkPad E14 Gen2 and installed Animated Lower Thirds with Dockable Control Panel v.1.6. But after downloading it, when I try to open the Lower Thirds Control Panel, this is what I got. Does anyone know how to fix it? Thanks a lot.
That plugin, lower thirds, hasn't been updated to OBS v28, it only works with OBS v27.x
Its author https://obsproject.com/forum/members/noeal.268657/ has gone missing and it is very unlikely it will be updated to the new OBS v28 anytime soon.
Check the status of plugins with the latest OBS here
The HTML is not meant for your browser. Go to OBS Top Menu → Docks → User defined Browser Docks (or something similar - I am not using the English version, so I have to guess what they are called :-) )
In there, you give your dock a name , e.g. "Animated lower 3rd" and under URL, type the exact link to the file. In my case it is "C:\Program Files\obs-studio\Animated-Lower-Thirds\lower thirds\control-panel.html". From that on, you will have the lower deck control panel available in your OBS and can activate / deactivate it under the "Docs" tab in the upper menu
You can also check Youtube. There are tons of Videos that explain how to use this Addon.
I got my first introduction by Michael Feyrer Jr. and Scott Fichter
I am using it under 28.0.3 and it is working fine
The plugin seems to work fine with v28 but the hotkey script always crashes OBS. I can enable the script but when I try and go to hotkeys OBS just crashes. I'd really like to use this plugin but I need hotkey support working.
I am using OBS 28.0.3 in Studio Mode and v.1.6 of this control. I am able to get it to work and it works well. However, when I turn on the Lower Third 1 (for example), it displays on both the Preview and Program windows. Is it possible to display it in the Preview window only? If so, would you please tell me how to do it?
Thanks,
Mike
OBS 21.1.2 the plugin doesn't work ... I mean it shows up but not any lower third is into the preview or the Program monitor at all ...
To be able to make it work, just uncheck the Local File checkbox and be sure file:/// appears before the local driver.
Does anyone have the issue, if you change the style option of the lower third, the logo option disappears completely and doesn't return, without resetting the config. I can replicate the issue every time, even with no config in there, i change the style and poof, logos disappear. Thoughts?
Haven't been able to find anyone else with my same lower thirds issue. Everything seems to be working fine typing in standard text but when trying in numbers, it automatically resets. It's as if not allowed to use numbers only letters. Can anyone help? Thanking you in advance.
Ok. I might not have a clue as to what you're talking about, but I want to help. Whenever I can't see something in OBS I find the resource in the list and resize it and it typically appears. I would even try to change the font size of the numbers. However, you used the words, "resets itself", so it sounds like I'm way off. Good luck!
Resizing may help, please look at what I typed below for spacetoonz. Good luck!
Hi NoeAL
I successfully installed an older version of "animated lower thirds....." and it's working great! However, I am not sure how to update as today you have updated this software. Which files or folders to replace or delete for the update. Should I just make a backup of the logos that I created and delete the file and folders that are all parts of the software and replace with the updated ones. Also, I am using a Mac and I seem to be able to use all the features that is demonstrated on your video and don't see the need for the upgrade. Thank You for developing this software. Pretty nice!
Hi NoeAL
If you read my previous message you will know how to make it work o OBS 28. Since it's nothing special in terms of used languages, just the PATH FORMAT is important
Hello everybody! I recently installed version 1.6 and it's working perfectly. However, I would like to know how to automate the rotation of the lowers (I'm using 3, Twitter, Instagram and TikTok). I'm breaking my head and I can't get this to work...LoL
Thank you for all your help and sorry for my English.
Does anyone have this working for OBS 29?
Thanks
Working Fine are you on windows or mac?
On windows , let say you have the files in a folder called c:\obs\lower3rds ( you will need to adjust for your case)
  • in the custom docks you need: file:///C:/obs/lower3rds/control-panel.html
  • in the browser source you need: 1. uncheck local file 2. file:///C://obs/lower3rds/browser-source.html
You should be okay.
You should be okay.
Windows, the CSS all looks screwed, will try redownloading....
Odd, overwriting fixed it, and its all working fine thanks for your kind help!
