Is there a possibility for an update that it would be possible to see the saved names instead of the number? An option for example that I can click a button and it will show the names line by line under eachother (like expanded tree) and I can choose from that list whom 3rd to use?
This way if I have many different speakers in an conference for example I dont need to make seperate explanation of the number who is under which number. So basically two types of views, one with number and then an alternative option that I proposed.
Hi. Why don't you use the memory slots?
That may be a fix for those for which 40 fields (4 LTs x 10 slots each) is not enough however I have a concern; by copyin the control-panel you create new instances that you can use but if I remember well, I read that all data is stored in the same files so you may end with corrupted info or when you close and open OBS your data in the different instances of the lower thirds control panne will be the same in all of them, Am I right? Actually I tried something like this in the past with earliest version of the LT but it did not work properly. My suggestion for the developer, add a field in the settings where you can choose how many LTs you want to add in the panel with 4 as default for example but if you need esxtra they can be added without need to add another panel, all of them in the same one, I think that would be a good enhancement.
Wonderfull Plug-In!
Would be nice to have two buttons/hotkeys for switching left/right throug the memory banks, not only individual hotkeys to each bank. Could save some buttons on Stream Deck.
Because if you want to point out for example an excerpt of a text, you lose the all integrity of the idea if you are going to shift between slots
What was the problem and how did you solve it? Share it with us. ;)
I sorted out unchecking "Enable hardware acceleration for the browser source" suggested in other posts.
Practically I couldn't see the lower thirds, but everything was showing that they were playing correctly (e.g.blue square)
Thanks
marco
This is a great plug-in. We have been using it for the past few weeks for our worship service. I do have a problem in that we set everything up for our service and it works great, but when we close out of OBS and re-open it, all of the LT Memory slots are empty and we have to recreate them. Is there something that I can do or check on our system that would allow the LT to not be lost when we close OBS? We are using
Animated Lower Thirds with Dockable Control Panel v.1.6 and OBS version 26.1.1
Hi!
I can't erase the name or the position. I click on "lear the text fields and set a logo to default" it disappears, but not from the slots. I enabled 1, 2, 3, 4 and 8 but when I click on clear, it disappears, but not the slots. Where am I going wrong?
Would love to see either the Name or Info field to be able to support multiple lines - either wrapping the text or supporting <br> tags. BTW, I love the tool, thank you!
-Chip
I love this tool.
I would like to have multiple "Output-Configs" for multiple Scenes. One Scene to two moderators, each one with his/her own lower third (left/right corner)
Second scene is moderator one with his/her lower third, third scene is moderator two with his/her lower third. All without manual enabeling the lower thirds just switching the scenes.
Hi!
I think this answer can help you:
Memory slot give the possibility to have 10 differents NAME, INFO, LOGOS for one LT. Fox example, in one team of basketball, you can enter all the players name's in the same LT (same configuration) in each slot.
Actions:
- To save something in one slot you have to write name and info and then click over the desired slot.
- To load slot, click over slot with number.
- To remove one slot, keep slot pressed until becomes red.
And that's it, you can view slots in action in this video https://www.youtube.com/watch?v=nKcvu-HwP9k&t=176s.
Hope this helps!
-Chip
Looks like I am not even 1 hour late to this request. +1 from me to have this possible.
Depending on the style, be able to support multiple lines could break up the designs. I think the best would be to have multi-line styles.
Anyway if you search here in the forum you will see that I have already shared how to modify the CSS to enable it.
I hope to add a useful solution for everyone in future updates.
