Free Animated lower thirds with control panel 2020-04-12
From1975 Lower Thirds might end up being one of the best things that has ever happen to OBS.
If there is one thing that has limit my use of OBS, it is lack of animated, dynamic and feed-in (csv et al) lower thirds.
I've use some plug-ins (Tobias stream overlay studio, Jaxel 8wr.io et al). They work great. However, from1975 is just simple to use and highly flexible. I guess it's time for me to start dusting my CSS and js.
This variant allows you to select colour for line 1 and line 2. For now, line three is by default red. Can be changed in the CSS.
PS: snapshot and zip file attached (note the source has not been clean up: lots of commented out codes.
NB: My attempt at using colour pick did not work (seems OBS browser limitation). Will appreciate if any can point int he right direction regarding colour picker. NB: it works in standalone browsers but not within OBS (dock).
Plan:
1. integrate @silvamichael SilvaMichael additional inputs;
2. include a glassy backdrop and text effect;
3. the "up" button doesn't work for now. It is a placeholder to scroll in from bottom.
- Hint: modify or remove animateout! Thanks @michaelc for the heads up.
4. additional buttons or use of drop-down list to control animation (right, fly, bottom, et al.);
5. explore possibility of parsing csv (or txt or excel) file.
6.
  • l3rd_obs01_snapshot_08Jul20_AKA01.zip
Plan:
6.
You said " My attempt at using colour pick did not work", i tested your files in OBS without any code change, i could select the color for the first file Line, couldn't for the second.
When testing with a browser, for the 1st line i could change the color everytime, however for the 2nd line, once the color is chosen it can't be changed unless the page is refreshed.
[/QUOTE
Thanks @RichieTee for the feedback. Deeply appreciated.
When using colour picker (HTML5 or js), the (colour selector) popup doesn't comes up. This works outside the OBS (dock) though.
My understanding is that OBS (dock) doesn't allow ContextMenu or direct interaction.
This is different for Browser source in OBS.
Possibly, there is something that needs to be enabled. I trust the community will assist in this regard. If so, then with css and js, we can have one instance of colour picker and possibly instantiate it for all the different text fields.
Hence, in the 'version' that was uploaded, the colour picker (native HMTL5 or js), was commented out.
HTML:
<!--//NotUsedAsOBSDoesntAllowContextMenu--// input type="color" id="lower-thirds-name-color"-->
[Currently]
For line 1, colour can be selected from the drop down (substituted colour picker).
For line two, users can select or simply type the colour they want/prefer. Obviously, this has a limitation of: typing correctly, and the typed colour recognised.
When testing with a browser, for the 1st line i could change the color every time, however for the 2nd line, once the color is chosen it can't be changed unless the page is refreshed.
Thanks. Yes, that is correct. Will look at fixing the 'bug'; .click, .change ....
It's got to do with the difference between colour selector for line 1 and line 2.
For line 1, it's simply <select> <option> ... </select> ... <input ...>.
For line 2, it's
HTML:
<input type="text" ...>
            <datalist id="color-list">
            <select name="fxn-color2">
            <option value="light grey" selected> light grey</option>
           </select ...
[Walkaround]
user should simply type in their desired colour. for line 2.
HTML:
[Currently]
[image]...
HTML:
 <select> <option> ... </select> ... <input ...>. [/CODE
For line 2, it's
[CODE=html]<input type="text" ...>
</select ...
[Walkaround]
Hey peeps, I've made a tutorial on how to use this and make a few customizations. Please check it out and leave me some feedback, good or bad.
Cheers.
Cheers.
Watched your video.
1) You should use a different note editor, so the colors can pop out.
2) You needed to delete and readd the browser dock to effect a change for the browser-source, when you could easily add the Reset Browser Source LUA from Exeldro "https://obsproject.com/forum/resources/reset-browsers-sources.966/". or use the Scene Browser Refresh by Alexik "https://obsproject.com/forum/resources/scene-browsers-refresh.1025/". As long as the changes is not on the Control Panel.html [browser dock], you don't need to delete and readd.
3) You could add an extra button to clear the text fields.
Aside that, your video shed proper light for those who prefer visual imagery. Cheers
Watched your video.
Thank you very much for those tips. There's so much I don't know about OBS and the vast resources you guys provide. Thanks again.
Thank you for the plugin. Is there anyway to add a background behind the text? Depending what's on the screen the text is not always visible. I'm not a CSS coding guy, so I appreciate the help.
Thank you.
Thank you.
Lots of people have answered this question.. Look above there should be an answer
This is because in the JavaScript code, the AnimateOut function clears the text fields. I modified mine and removed that code.
This plugin is fantastic if you understand HTML, CSS, and JavaScript. But if you don't, it's probably the wrong tool to use.
Would you mind pointing out the code you modified to make text animate in and out instead of popping out?
Thanks.
Very good work. I'll look later and do some tests. But from the video I realized that it has a lot of flexibility.
Hi! Thanks for this amazing tool.
Inspired by this I've created one that I would like to share with everyone. I hope that it would be useful to someone.
https://obsproject.com/forum/resources/animated-lower-thirds-with-dockable-control-panel.1057/
See how it works: https://youtu.be/DIpslG-u7k0
Once again, thank you for your work!
Thank you for the plugin!
Two Issues I've:
1. On my Mac, when the scene with the browser source loads for the first time, the logo displays by default. Is it possible to have the logo be hidden by default?
2. Backspace does not work with the text fields on OSX. I can only overwrite entered text by selecting it and typing over.
This is an awesome resource. Thank you so much for providing it to us!
Does anyone know how to resize the logo? I have replaced the logo with ours, but even if I resize the png in an editing software, it still shows the same size (just grainier). So somewhere there must be a location to do that. I just can't find it in the css file.
