Want To Learn
Member
i'm not a programmer, so I am only guessing. My virtual assistant had me try to manually install it, but I didn't see the . so file. However, I saw the data file. Maybe this will help. Thanks.
Hi Horaiken 1.0.5 Their was a load error. Same as last version for the Mac by Stream up. "adjustment-layer ⚠️ Failed to Load Not Supported OBS Forums" Thank you for all your efforts. Prayerfully next update?
Awe.. I should have mentioned that I'm using an intel Mac. Unfortunately an upgrade in computers is not financially possible right now. Someday.....Thanks.Ah, could it be that you’re using an Intel-based Mac?
I’ve been developing this for Apple Silicon, so that might explain the issue.
Awe.. I should have mentioned that I'm using an intel Mac. Unfortunately an upgrade in computers is not financially possible right now. Someday.....Thanks........any possibility it will be available for Intel Mac in the future? I don't know what the differences are in coding and how hard it is to do, so I don't know. Thanks.
This release fixes critical freezing and crashing issues that occurred when creating or deleting the Adjustment Layer, particularly on Windows and when used alongside specific other plugins.
本リリースは、特定の環境下(Windowsや他のプラグインとの併用時)において、調整レイヤーの作成・削除の際にOBS全体がフリーズまたはクラッシュする問題を修正するバグフィックスリリースです。
Bug Fixes
Fix GPU driver crashes and freezes on layer removal (especially on Windows/D3D11)
- Deleting the...
This release adds support for source show and hide transitions and improves the overall stability of the Adjustment Layer. It also prevents unsupported placements from causing unexpected behavior by displaying a clear warning instead.
本リリースでは、ソースの表示・非表示トランジションに対応し、調整レイヤー全体の安定性を向上しました。また、未対応の配置による予期しない動作を防ぎ、代わりに分かりやすい警告を表示するようにしました。
New Features
- Sources below the Adjustment Layer now correctly use their configured show and hide transitions...
This release fixes an issue where an Adjustment Layer could incorrectly display the shared-use warning and stop working when its scene was placed inside another scene. Scenes containing an Adjustment Layer can now be nested without being mistaken for duplicate use.
本リリースでは、調整レイヤーを含むシーンを別のシーンに入れ子で配置した際、共有使用の警告が誤って表示され、調整レイヤーが動作しなくなる問題を修正しました。調整レイヤーを含むシーンを入れ子で使用しても、複製使用と誤判定されなくなりました。
Bug Fixes
- Fixed a false warning that could disable an Adjustment...
Thank you for this workaround. I love Horaiken and use his .lua's but unfortunately this is not available for intel macs.Hi. I use groups. You can place a group that has your overlays / sources in each scene. you turn any in the group , on or off and it affects all scenes when that scene is visible. This includes text and video overlay sources
