2nd source wich is the same as in 1st, wont work...
LureMask
First I have a logitech c922x camera.
i made the 1st scene with 2 sources:
1- display capture - works fine
2- video capture device - works just fine as well
then I made the 2nd scene where I wanted to show only my face on the camera
when I make a new source-video capture device and selecting the same camera as I did in the first scene, it won't show...
any suggestions?
photos:
They aren't the same and that's the problem.
Use add existing, not add new.
great! thanks!
but now I have another problem...
I want the 2nd scene to be the camera only and when I use this source and enlarge it - it changes the way the 1st scene look...
can I address it?
You can create a scene just with the camera source (remove camera from existing scenes). Then add the camera scene to both of your existing scenes. Now you can resize / crop the camera in each scene.
