버튜버를 준비하는데요. 모델이 OBS에만 송출되고 Window 화면에는 모델 창이 나타나지 않아요.
soo111
문의 할 곳이 없어서 여기가 맞는지 모르겠지만 누가 좀 도와주실 수 있나요?
I'm preparing a virtual YouTuber. The model is sent only to OBS and the " Window screen " does not show the model window.
I don't know if this is the right place as I don't have anywhere to inquire, but can someone help me?
원인을 몰라서 검색을 할 수 없고요.
구글링을 해 보았는데 이런 경우를 못 찾아서 해결할 수 없었습니다.
I can't search because I don't know the cause.
I've tried Googling, but I couldn't solve this case because I couldn't find it.
please help me.
19:22:32.506: [win_spout] [Spout2 Capture] Getting info for sender VTubeStudioSpout
19:22:32.506: [win_spout] [Spout2 Capture] Sender VTubeStudioSpout is of dimensions 1718 x 1360
19:22:55.718: [game-capture: '게임 캡쳐'] attempting to hook process: VTube Studio.exe
19:22:55.738: [game-capture: '게임 캡쳐'] DXGI_SWAP_CHAIN_DESC:
19:22:55.738:     BufferDesc.Width: 1718
19:22:55.738:     BufferDesc.Height: 1360
19:22:55.738:     BufferDesc.RefreshRate.Numerator: 0
19:22:55.738:     BufferDesc.RefreshRate.Denominator: 1
19:22:55.738:     BufferDesc.Format: 28
19:22:55.738:     BufferDesc.ScanlineOrdering: 0
19:22:55.738:     BufferDesc.Scaling: 0
19:22:55.738:     SampleDesc.Count: 1
19:22:55.738:     SampleDesc.Quality: 0
19:22:55.738:     BufferUsage: 48
19:22:55.738:     BufferCount: 2
19:22:55.738:     Windowed: 1
19:22:55.738:     SwapEffect: 3
19:22:55.738:     Flags: 2114
19:22:55.739: [game-capture: '게임 캡쳐'] d3d11 shared texture capture successful
19:22:55.752: [game-capture: '게임 캡쳐'] shared texture capture successful
19:22:59.781: [game-capture: '게임 캡쳐'] Hooked SwapBuffers
19:22:59.781: [game-capture: '게임 캡쳐'] Hooked wglDeleteContext
19:22:59.781: [game-capture: '게임 캡쳐'] Hooked wglSwapLayerBuffers
19:22:59.781: [game-capture: '게임 캡쳐'] Hooked wglSwapBuffers
19:22:59.781: [game-capture: '게임 캡쳐'] Hooked GL
Both attempts were successful. Should work fine. If your source lies out of the Preview window, then you may try to Transform (Ctrl + E) the source position on. The top left corner in OBS is (x = 0 px; y = 0 px), the "x" axis values increases from left to right, the "y" values - from top to bottom.
